Re: [cgal-discuss] Error when using CGAL 4.0.2 libs built by CGAL4.0.2 + Qt4.8.2 + boost1.50.0 + VS2010
- To:
- Subject: Re: [cgal-discuss] Error when using CGAL 4.0.2 libs built by CGAL4.0.2 + Qt4.8.2 + boost1.50.0 + VS2010
- Date: Tue, 14 Aug 2012 09:47:14 +0200
Zhanghong Tang
writes:
> Dear all,
> I have built the CGAL4.0.2 32 bit libs by CGAL4.0.2 + Qt4.8.2 + boost1.50.0
> + VS2010. However, when using the libs
> libCGAL_Core-vc100-mt-gd-4.0.2.lib and libCGAL-vc100-mt-gd-4.0.2.lib
> in my code, the following error displayed:
> 1>libboost_thread-vc100-mt-gd-1_50.lib(thread.obj) : error LNK2019:
> unresolved external symbol "public: static class
> boost::chrono::time_point<class boost::chrono::system_clock,class
> boost::chrono::duration<__int64,class boost::ratio<1,10000000> > >
> __cdecl boost::chrono::system_clock::now(void)"
> (?now@system_clock@chrono@boost@@SA?AV?$time_point@Vsystem_clock@chrono@boost@@V?$duration@_JV?$ratio@$00$0JIJGIA@@boost@@@23@@23@XZ)
> referenced in function "public: bool __thiscall
> boost::thread::try_join_until(class boost::chrono::time_point<class
> boost::chrono::duration<__int64,class boost::ratio<1,1000000000> > >
> const &)"
> (?try_join_until@thread@boost@@QAE_NABV?$time_point@Vsystem_clock@chrono@boost@@V?$duration@_JV?$ratio@$00$0DLJKMKAA@@boost@@@23@@chrono@2@@Z)
> The code works well when using the libs by
> CGAL3.9 + Qt4.7.2 + boost1.47.0 + VS2010.
Apparently Boost.Thread requires to be linked against chrono in 1.50 if
you are calling certain functions. However, this shouldn't be the case
for any CGAL code. If you are using Boost.Thread yourself, make sure to
link against all its dependencies [1].
Footnotes:
[1] http://www.boost.org/doc/libs/1_50_0/doc/html/thread/build.html
HTH,
Philipp
- [cgal-discuss] Error when using CGAL 4.0.2 libs built by CGAL4.0.2 + Qt4.8.2 + boost1.50.0 + VS2010, Zhanghong Tang, 08/14/2012
- RE: [cgal-discuss] Error when using CGAL 4.0.2 libs built by CGAL4.0.2 + Qt4.8.2 + boost1.50.0 + VS2010, Zhanghong Tang, 08/14/2012
- Re: [cgal-discuss] Error when using CGAL 4.0.2 libs built by CGAL4.0.2 + Qt4.8.2 + boost1.50.0 + VS2010, Philipp Moeller, 08/14/2012
