Re: [cgal-discuss] About the implementation of HalfedgeDS_decorator<HDS>::join_vertex
- To:
- Subject: Re: [cgal-discuss] About the implementation of HalfedgeDS_decorator<HDS>::join_vertex
- Date: Sun, 19 Aug 2012 11:27:57 +0200
On 08/14/2012 03:59 AM, Liyang wrote:
Hi experts,The code is correct and the vertex of gprev has been updated.
I'm reading the code of HalfedgeDS_decorator<HDS>::join_vertex , the
question is, after the loop(while(h!=gprev)...), all halfedges
previously pointed to get_vertex(gprev) but gprev have pointed to
get_vertex(hprev), don't we need to make gprev point to get_vertex(hprev)?
Indeed, the loop is the following:
while ( h != gprev) {
CGAL_assertion( ++termination_count != 0);
h = h->next()->opposite();
set_vertex( h, get_vertex( hprev));
//when I'm here h==gprev which means that the last time I did
// set_vertex, I updated the vertex of h.
Sebastien.
Thank you for your attention and sorry for my poor English.
Best regards.
/* The codes are as follow */
Halfedge_handle join_vertex( Halfedge_handle h) {
// joins the two vertices incident to h. The vertex denoted by
// `h->opposite()' gets removed by `hds'. Returns the predecessor
// of h around the vertex. The invariant `join_vertex(
// split_vertex( h, g))' returns h and keeps the polyhedron
// unchanged. The time is proportional to the degree of the vertex
// removed and the time to compute `h->prev()'. Precondition:
// `Supports_removal' == `Tag_true'.
Assert_compile_time_tag( Tag_true(), Supports_removal());
Halfedge_handle hprev = find_prev( h->opposite());
Halfedge_handle gprev = find_prev( h);
remove_halfedge( hprev);
remove_halfedge( gprev);
hds->edges_erase( h);
vertices_erase( get_vertex( gprev));
// 'half' of the halfedges have their correct vertex.
// Here we do the remaining halfedges.
h = hprev;
CGAL_assertion_code( std::size_t termination_count = 0;)
set_vertex_halfedge( hprev);
if ( ! hprev->is_border())
set_face_halfedge( hprev);
if ( ! gprev->is_border())
set_face_halfedge( gprev);
return hprev;
2012-08-14
Liyang
- [cgal-discuss] About the implementation of HalfedgeDS_decorator<HDS>::join_vertex, Liyang, 08/14/2012
- Re: [cgal-discuss] About the implementation of HalfedgeDS_decorator<HDS>::join_vertex, Sebastien Loriot (GeometryFactory), 08/19/2012
