cgal-discuss - [cgal-discuss] 3D volume mesher ignoring small subdomains
  • To:
  • Subject: [cgal-discuss] 3D volume mesher ignoring small subdomains
  • Date: Fri, 24 Aug 2012 05:34:39 -0700 (PDT)
Hi,
I am using the 3D Mesh Generator from CGAL 3.9 to create meshes from
multi-label segmentations. The code is working well except for one thing:
If my domain contains a sub-domain whose characteristic size is about two
orders of magnitude lower then the whole domain (imagine for example a two
millimetre thick needle inside a 100x100x100 mm sized block of tissue), this
sub-domain is simply ignored by the mesher. I tried setting different cell
and surface radii for the different labels using a sizing field and also
played with the other available parameters but can't get it to work. I also
tried to resample my image such that the spacing is smaller but with no
effect.
Do you have any hints about what is going wrong?
Thanks,
Sascha
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-volume-mesher-ignoring-small-subdomains-tp4655756.html
  • [cgal-discuss] 3D volume mesher ignoring small subdomains, sascha, 08/24/2012
