cgal-discuss - Re: [cgal-discuss] Is there a number_of_faces() method that considers the mesh domain
  • To:
  • Subject: Re: [cgal-discuss] Is there a number_of_faces() method that considers the mesh domain
  • Date: Wed, 29 Aug 2012 14:30:14 +0200
On 08/29/2012 12:45 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
Le mercredi 29 août 2012 03:29:28 gerth a écrit :
Hello!
I am using a Constrained_Delaunay_triangulation_2 in combination with a
Delaunay_mesher_2 to mesh a polygon area.
I noticed that I can use the number_of_faces() method to get the number of
resulting faces of my mesh. However, some faces are outside of the polygon.
When I iterate over the faces with a Finite_faces_iterator, I can use the
is_in_domain() function to determine whether the face lies within the
polygon or not.
I was wondering if there is a function similar to number_of_faces(), that
returns only those faces that are within the polygon. Of course I can
iterate over the result and count all the faces where is_in_domain() returns
true, but that doesn't seem very efficient to me.
You are right that this function does not exist. And it is not plan to add it.
It could not be a member function, because the object "mesh" is actually a
Constrained_Delaunay_triangulation_2, and not a type dedicated to meshing.
Note that you could use boost::filter_iterator and std::distance to do that.
Sebastien.
