cgal-discuss - [cgal-discuss] [Bug Report] Failed when compiling CGAL4.0.2 with Boost1.50.0 or 1.51.0
  • To:
  • Subject: [cgal-discuss] [Bug Report] Failed when compiling CGAL4.0.2 with Boost1.50.0 or 1.51.0
  • Date: Wed, 29 Aug 2012 15:44:24 -0500
I spent two crazy days to configure CGAL for VS2010.
My compiler is MSVC10 (runs in Win7 x64). I downloaded Qt4.8.2, CGAL4.0.2, CMake2.8.9, and Boost1.51.0(or 1.50.0), which are all the most recent versions.
I followed some online instructions to set things up.
With no surprise, CMake cannot find "boost_thread" lib no matter how I set the env_vars and cmake_vars.
I dug out a post in Chinese that gave me a probably correct solution, which is to rename all "libboost-xxx" files to "boost-xxx" in ${BOOST_ROOT}/lib directory.
OK. Then I was able to get the "CGAL.sln" solution file. But when I tried to compile it in VC++2010 express, a new problem came. It seemed that some symbols are unrecognized? (I'm not sure about this)
Here is the message in VC++2010express:
"1>------ Build started: Project: ZERO_CHECK, Configuration: Release Win32 ------
2>------ Build started: Project: CGAL, Configuration: Release Win32 ------
2>     Creating library I:/Program Files/CGAL-4.0.2/lib/Release/CGAL-vc100-mt-4.0.2.lib and object I:/Program Files/CGAL-4.0.2/lib/Release/CGAL-vc100-mt-4.0.2.exp
2>all_files.obj : warning LNK4217: locally defined symbol ?set_tss_data@detail@boost@@YAXPBXV?$shared_ptr@Utss_cleanup_function@detail@boost@@@2@PAX_N@Z (void __cdecl boost::detail::set_tss_data(void const *,class boost::shared_ptr<struct boost::detail::tss_cleanup_function>,void *,bool)) imported in function "public: __thiscall boost::thread_specific_ptr<int>::~thread_specific_ptr<int>(void)" (??1?$thread_specific_ptr@H@boost@@QAE@XZ)
2>all_files.obj : warning LNK4217: locally defined symbol ?generic_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::generic_category(void)) imported in function "void __cdecl boost::system::`dynamic initializer for 'posix_category''(void)" (??__Eposix_category@system@boost@@YAXXZ)
2>all_files.obj : warning LNK4217: locally defined symbol ?system_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::system_category(void)) imported in function "void __cdecl boost::system::`dynamic initializer for 'native_ecat''(void)" (??__Enative_ecat@system@boost@@YAXXZ)
2>boost_thread-vc100-mt-1_50.lib(thread.obj) : error LNK2019: unresolved external symbol "public: static class boost::chrono::time_point<class boost::chrono::system_clock,class boost::chrono::duration<__int64,class boost::ratio<1,10000000> > > __cdecl boost::chrono::system_clock::now(void)" (?now@system_clock@chrono@boost@@SA?AV?$time_point@Vsystem_clock@chrono@boost@@V?$duration@_JV?$ratio@$00$0JIJGIA@@boost@@@23@@23@XZ) referenced in function "public: bool __thiscall boost::thread::try_join_until(class boost::chrono::time_point<class boost::chrono::system_clock,class boost::chrono::duration<__int64,class boost::ratio<1,1000000000> > > const &)" (?try_join_until@thread@boost@@QAE_NABV?$time_point@Vsystem_clock@chrono@boost@@V?$duration@_JV?$ratio@$00$0DLJKMKAA@@boost@@@23@@chrono@2@@Z)
2>I:\Program Files\CGAL-4.0.2\bin\Release\CGAL-vc100-mt-4.0.2.dll : fatal error LNK1120: 1 unresolved externals
3>------ Build started: Project: CGAL_Core, Configuration: Release Win32 ------
4>------ Build started: Project: CGAL_ImageIO, Configuration: Release Win32 ------
5>------ Build started: Project: CGAL_Qt4, Configuration: Release Win32 ------
3>     Creating library I:/Program Files/CGAL-4.0.2/lib/Release/CGAL_Core-vc100-mt-4.0.2.lib and object I:/Program Files/CGAL-4.0.2/lib/Release/CGAL_Core-vc100-mt-4.0.2.exp
3>  CGAL_Core.vcxproj -> I:\Program Files\CGAL-4.0.2\bin\Release\CGAL_Core-vc100-mt-4.0.2.dll
4>     Creating library I:/Program Files/CGAL-4.0.2/lib/Release/CGAL_ImageIO-vc100-mt-4.0.2.lib and object I:/Program Files/CGAL-4.0.2/lib/Release/CGAL_ImageIO-vc100-mt-4.0.2.exp
4>all_files.obj : warning LNK4217: locally defined symbol ?generic_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::generic_category(void)) imported in function "void __cdecl boost::system::`dynamic initializer for 'posix_category''(void)" (??__Eposix_category@system@boost@@YAXXZ)
4>all_files.obj : warning LNK4217: locally defined symbol ?system_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::system_category(void)) imported in function "void __cdecl boost::system::`dynamic initializer for 'native_ecat''(void)" (??__Enative_ecat@system@boost@@YAXXZ)
4>boost_thread-vc100-mt-1_50.lib(thread.obj) : error LNK2019: unresolved external symbol "public: static class boost::chrono::time_point<class boost::chrono::system_clock,class boost::chrono::duration<__int64,class boost::ratio<1,10000000> > > __cdecl boost::chrono::system_clock::now(void)" (?now@system_clock@chrono@boost@@SA?AV?$time_point@Vsystem_clock@chrono@boost@@V?$duration@_JV?$ratio@$00$0JIJGIA@@boost@@@23@@23@XZ) referenced in function "public: bool __thiscall boost::thread::try_join_until(class boost::chrono::time_point<class boost::chrono::system_clock,class boost::chrono::duration<__int64,class boost::ratio<1,1000000000> > > const &)" (?try_join_until@thread@boost@@QAE_NABV?$time_point@Vsystem_clock@chrono@boost@@V?$duration@_JV?$ratio@$00$0DLJKMKAA@@boost@@@23@@chrono@2@@Z)
4>I:\Program Files\CGAL-4.0.2\bin\Release\CGAL_ImageIO-vc100-mt-4.0.2.dll : fatal error LNK1120: 1 unresolved externals
3>          1 file(s) copied.
5>     Creating library I:/Program Files/CGAL-4.0.2/lib/Release/CGAL_Qt4-vc100-mt-4.0.2.lib and object I:/Program Files/CGAL-4.0.2/lib/Release/CGAL_Qt4-vc100-mt-4.0.2.exp
5>all_files.obj : warning LNK4217: locally defined symbol ?generic_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::generic_category(void)) imported in function "void __cdecl boost::system::`dynamic initializer for 'posix_category''(void)" (??__Eposix_category@system@boost@@YAXXZ)
5>moc_GraphicsItem.obj : warning LNK4049: locally defined symbol ?generic_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::generic_category(void)) imported
5>moc_GraphicsViewInput.obj : warning LNK4049: locally defined symbol ?generic_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::generic_category(void)) imported
5>all_files.obj : warning LNK4217: locally defined symbol ?system_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::system_category(void)) imported in function "void __cdecl boost::system::`dynamic initializer for 'native_ecat''(void)" (??__Enative_ecat@system@boost@@YAXXZ)
5>moc_GraphicsItem.obj : warning LNK4049: locally defined symbol ?system_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::system_category(void)) imported
5>moc_GraphicsViewInput.obj : warning LNK4049: locally defined symbol ?system_category@system@boost@@YAABVerror_category@12@XZ (class boost::system::error_category const & __cdecl boost::system::system_category(void)) imported
5>boost_thread-vc100-mt-1_50.lib(thread.obj) : error LNK2019: unresolved external symbol "public: static class boost::chrono::time_point<class boost::chrono::system_clock,class boost::chrono::duration<__int64,class boost::ratio<1,10000000> > > __cdecl boost::chrono::system_clock::now(void)" (?now@system_clock@chrono@boost@@SA?AV?$time_point@Vsystem_clock@chrono@boost@@V?$duration@_JV?$ratio@$00$0JIJGIA@@boost@@@23@@23@XZ) referenced in function "public: bool __thiscall boost::thread::try_join_until(class boost::chrono::time_point<class boost::chrono::system_clock,class boost::chrono::duration<__int64,class boost::ratio<1,1000000000> > > const &)" (?try_join_until@thread@boost@@QAE_NABV?$time_point@Vsystem_clock@chrono@boost@@V?$duration@_JV?$ratio@$00$0DLJKMKAA@@boost@@@23@@chrono@2@@Z)
5>I:\Program Files\CGAL-4.0.2\bin\Release\CGAL_Qt4-vc100-mt-4.0.2.dll : fatal error LNK1120: 1 unresolved externals
6>------ Build started: Project: ALL_BUILD, Configuration: Release Win32 ------
6>  Build all projects
========== Build: 3 succeeded, 3 failed, 0 up-to-date, 0 skipped =========="
This problem is far beyond my ability. As a result, I turn back to older versions of CGAL (3.9.0) and Boost (1.47.0).  I use exactly the same setup procedure, and everything goes well till now.
I think there is a problem if we want to use some current versions of CGAL and Boost together.
I also have a suggestion:
Since CGAL desperately depends on Boost, please specifically list which versions of Boost are required by each version of CGAL.
BTW, the installation manual says that CGAL4.0.2 requires Boost 1.39.0 or newer, but it definitely cannot work with Boost 1.50.0 or 1.51.0, which are of course newer than 1.39.0.
Thanks,
Wei
