cgal-discuss - Re: [cgal-discuss] [Bug Report] Failed when compiling CGAL4.0.2 with Boost1.50.0 or 1.51.0
  • To:
  • Subject: Re: [cgal-discuss] [Bug Report] Failed when compiling CGAL4.0.2 with Boost1.50.0 or 1.51.0
  • Date: Thu, 30 Aug 2012 11:57:13 +0200
Le mercredi 29 août 2012 15:44:24 Wei Li a écrit :
> I spent two crazy days to configure CGAL for VS2010.
> My compiler is MSVC10 (runs in Win7 x64). I downloaded Qt4.8.2, CGAL4.0.2,
> CMake2.8.9, and Boost1.51.0(or 1.50.0), which are all the most recent
> versions.
> I followed some online instructions to set things up.
> With no surprise, CMake cannot find "boost_thread" lib no matter how I set
> the env_vars and cmake_vars.
> I dug out a post in Chinese that gave me a probably correct solution, which
> is to rename all "libboost-xxx" files to "boost-xxx" in ${BOOST_ROOT}/lib
> directory.
Well, the solution of that post was a wrong idea. libboost-*.lib files are
static libraries, where as boost-*.lib files are dynamic libraries (that need
the boost-*.dll DLLs at runtime in the PATH).
If you have downloaded the static libraries of Boost, and only those, then
you
need to switch the CMake variable CGAL_Boost_USE_STATIC_LIBS to "TRUE".
> OK. Then I was able to get the "CGAL.sln" solution file. But when I tried to
> compile it in VC++2010 express, a new problem came. It seemed that some
> symbols are unrecognized? (I'm not sure about this)
> Here is the message in VC++2010express:
> "1>------ Build started: Project: ZERO_CHECK, Configuration: Release Win32
> ------ 2>------ Build started: Project: CGAL, Configuration: Release Win32
> ------ 2> Creating library I:/Program
> Files/CGAL-4.0.2/lib/Release/CGAL-vc100-mt-4.0.2.lib and object I:/Program
> Files/CGAL-4.0.2/lib/Release/CGAL-vc100-mt-4.0.2.exp 2>all_files.obj :
> warning LNK4217: locally defined symbol
> ?set_tss_data@detail@boost@@YAXPBXV?$shared_ptr@Utss_cleanup_function@detai
> l@boost@@@2@PAX_N@Z (void __cdecl boost::detail::set_tss_data(void const
> *,class boost::shared_ptr<struct boost::detail::tss_cleanup_function>,void
> *,bool)) imported in function "public: __thiscall
> boost::thread_specific_ptr<int>::~thread_specific_ptr<int>(void)"
> (??1?$thread_specific_ptr@H@boost@@QAE@XZ)
This warning is a consequence off your use of static Boost libraries in a
configuration where dynamic Boost libraries were expected.
> 2>boost_thread-vc100-mt-1_50.lib(thread.obj) : error LNK2019: unresolved
> external symbol "public: static class boost::chrono::time_point<class
> boost::chrono::system_clock,class boost::chrono::duration<__int64,class
> boost::ratio<1,10000000> > > __cdecl
> boost::chrono::system_clock::now(void)"
> (?now@system_clock@chrono@boost@@SA?AV?$time_point@Vsystem_clock@chrono@boo
> st@@V?$duration@_JV?$ratio@$00$0JIJGIA@@boost@@@23@@23@XZ) referenced in
> function "public: bool __thiscall boost::thread::try_join_until(class
> boost::chrono::time_point<class boost::chrono::system_clock,class
> boost::chrono::duration<__int64,class boost::ratio<1,1000000000> > > const
> (?try_join_until@thread@boost@@QAE_NABV?$time_point@Vsystem_clock@chrono@bo
> ost@@V?$duration@_JV?$ratio@$00$0DLJKMKAA@@boost@@@23@@chrono@2@@Z)
That is a linker error. It seems that Boost.Thread, on Windows, from
Boost 1.50.0, does require to link with Boost.Chrono and Boost.System. What I
do not understand is that, on Windows, the auto-linking feature of Boost
libraries should have make the CGAL libraries linked with the needed Boost
libraries. Have you disabled the auto-linking feature of Boost with special
CMake variables? Or maybe the missing symbols are another consequence of your
renaming of static libraries to shared libraries.
> This problem is far beyond my ability. As a result, I turn back to older
> versions of CGAL (3.9.0) and Boost (1.47.0). I use exactly the same setup
> procedure, and everything goes well till now.
> I think there is a problem if we want to use some current versions of CGAL
> and Boost together.
> I also have a suggestion:
> Since CGAL desperately depends on Boost, please specifically list which
> versions of Boost are required by each version of CGAL. BTW, the
> installation manual says that CGAL4.0.2 requires Boost 1.39.0 or newer, but
> it definitely cannot work with Boost 1.50.0 or 1.51.0, which are of course
> newer than 1.39.0.
You are right. We will publish the list of versions that were tested at the
date of the publication of a new CGAL release. Boost 1.50.0 and latter were
not tested with CGAL-4.0.2. CGAL-4.1 does support Boost 1.50.0, but was not
tested with Boost 1.51.0.
Laurent Rineau, PhD
