- To:
- Subject: [cgal-discuss] Intersections between plane and "surface"
- Date: Fri, 31 Aug 2012 08:09:48 -0700 (PDT)
Hi everybody.
I'm a new user of cgal and I have a question.
I'm working with 3D polygons. These polygons are set of several 3D points in
the same plane.
My question is that :
What type of object I need to declare in order to have a plain 3D polygon
(i.e the intersection between this object and a plane gives a segment but
not a set of points, that is the result of an intersection between a 2D
polygon and a plane).I don't know if I am clear, so I give a picture to
illustrate that.
http://cgal-discuss.949826.n4.nabble.com/file/n4655784/intersection.png
Thank you for your reply.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Intersections-between-plane-and-surface-tp4655784.html
- [cgal-discuss] Intersections between plane and "surface", babaOroms, 08/31/2012
