- To:
- Subject: Re: [cgal-discuss] Why nothing is drawn in this program
- Date: Thu, 6 Sep 2012 09:13:02 -0700
Hi,
Before this line:
scene.addItem(&arcItem);
Try to add this:
scene.setSceneRect( arcItem.boundingRect() );
This should set the view to fit the arc in the visible area.
--Alex
On Thu, Sep 6, 2012 at 6:03 AM, Wang Hetao <> wrote:
I got help from Alex Tsui this afternoon about how to draw arcs with Qt. see:
http://cgal-discuss.949826.n4.nabble.com/How-to-draw-arcs-under-Qt-td4655803.html
I wrote a program according to his guidance as follows:
#include <CGAL/Exact_circular_kernel_2.h>
#include <CGAL/Qt/CircularArcGraphicsItem.h>
#include <CGAL/Qt/GraphicsViewNavigation.h>
#include <CGAL/Qt/PainterOstream.h>
#include <QGraphicsView>
#include <QGraphicsScene>
#include <QRectF>
#include <QPen>
#include <QWidget>
#include <QPainter>
#include <QColor>
#include <QApplication>
typedef CGAL::Exact_circular_kernel_2 Circular_K;
typedef CGAL::Qt::CircularArcGraphicsItem<Circular_K>
CircularArcGraphicsItem;
typedef CGAL::Point_2<Circular_K> CK_Point;
typedef CGAL::Circle_2<Circular_K> CK_Circle;
typedef CGAL::Circular_arc_2<Circular_K> Circular_arc;
typedef CGAL::Circular_arc_point_2<Circular_K> Circular_arc_point;
int main(int argc, char *argv[]){
QApplication app(argc, argv);
QGraphicsScene scene;
QWidget widget;
QPainter painter;
QGraphicsView view(&scene);
CGAL::Qt::GraphicsViewNavigation navigation;
CK_Circle circle(CK_Point(100, 100), 100*100);
CircularArcGraphicsItem arcItem;
arcItem.setArc(Circular_arc(circle, Circular_arc_point(CK_Point(100,
0)), Circular_arc_point(CK_Point(0, 100))));
arcItem.setEdgesPen(QPen(QColor(255, 0, 0)));
view.installEventFilter(&navigation);
view.viewport()->installEventFilter(&navigation);
view.show();
//widget.show();
return app.exec();
It can be complied and run properly, and a white window appeared. I intended
to draw a red circular arc on it but nothing was drawn.
I'm so confused now, The program should be correct but the result is wrong.
Thx for your reply.
PS: If you want to compile the program above under Qt IDE, the following two
lines should be added in your project file(suffix is .pro):
LIBS += -L /usr/local/bin/ -lCGAL
LIBS += -L /usr/local/bin/ -lCGAL_Qt4
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Why-nothing-is-drawn-in-this-program-tp4655807.html
- [cgal-discuss] Why nothing is drawn in this program, Wang Hetao, 09/06/2012
- Re: [cgal-discuss] Why nothing is drawn in this program, Alex Tsui, 09/06/2012
- [cgal-discuss] Re: Why nothing is drawn in this program, Wang Hetao, 09/07/2012
