- To:
- Subject: Re: [cgal-discuss] OFF to PNG
- Date: Mon, 10 Sep 2012 15:58:02 -0500
Hi all,
I not agree with your comments 'cause the convertion of a file OFF (3D data) toward a PNG (2D data) it not possible; unless you want a capture of the tridimentional representation of OFF format into an image PNG or a projection of the 3D to 2D. bye Felipe Trujillo-Romero PhD. Sistemas Informáticos Universidad Tecnologica de la Mixteca México On Mon, 10 Sep 2012 22:56:30 +0200, David Canino wrote > Good morning, > > the member function I mentioned saves the content of the frame buffer, so first you load and draw your shape, and then save the content of the current frame. It is a common practice in any program exploiting the QT Library. > > Best regards > > David Canino > > 2012/9/10 Noel Warren <> > Sounds promising. I haven't used the Qt library but I know that you add your widgets and then execute the app. Would I have to execute the app before being able to toy around with the view of the widget, or could I create my images without executing the app? |
- [cgal-discuss] OFF to PNG, Noel Warren, 09/10/2012
- Re: [cgal-discuss] OFF to PNG, David Canino, 09/10/2012
- Re: [cgal-discuss] OFF to PNG, Noel Warren, 09/10/2012
- Re: [cgal-discuss] OFF to PNG, Felipe de Jesus Trujillo Romero, 09/10/2012
- [cgal-discuss] Re: OFF to PNG, Oleg, 09/19/2012
