- To: <>
- Subject: RE: [cgal-discuss] Error in CGAL bool operation
- Date: Fri, 14 Sep 2012 16:25:32 +1200
- Importance: Normal
Dear all,
The code should be as follows:
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <iostream>
#include <istream>
#include <fstream>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Nef_polyhedron_3.h>
#include "math.h"
using namespace std;
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Simple_cartesian<double> sKernel;
typedef Kernel::Point_3 Point_3;
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::HalfedgeDS HalfedgeDS;
typedef Kernel::Plane_3 Plane_3;
typedef Polyhedron::Vertex_iterator Vertex_iterator;
typedef Polyhedron::Facet_iterator Facet_iterator;
typedef Polyhedron::Halfedge_around_facet_circulator Halfedge_facet_circulator;
typedef Nef_polyhedron::Aff_transformation_3 Aff_transformation_3;
typedef Nef_polyhedron::Vector_3 Vector_3;
void readoff(Polyhedron *P,char *filename)
std::ifstream stream(filename);
stream >> *P;
void BoolObject3(char *op, char *file1,char *file2,char *outfile)
Polyhedron P1, P2;
readoff(&P1,file1);
readoff(&P2,file1);
Nef_polyhedron NP1(P1);
Nef_polyhedron NP2(P2);
switch(*op)
case '+': NP1 = NP1 + NP2;break;
case '-': NP1 = NP1 - NP2;break;
case '*': NP1 = NP1 * NP2;break;
case '^': NP1 = NP1 ^ NP2;break;
default:break;
NP1.convert_to_polyhedron(P1);
// output the polyhedron to OFF file
std::ofstream log(outfile);
std::streambuf * oldbuf = std::cout.rdbuf(log.rdbuf());
std::cout << P1;
std::cout.rdbuf( oldbuf);
int main()
BoolObject3("+", "a1.off","a2.off","a3.off");
Thanks,
Zhanghong Tang
#include <iostream>
#include <istream>
#include <fstream>
#include "math.h"
stream >> *P;
Polyhedron P1, P2;
readoff(&P1,file1);
readoff(&P2,file1);
switch(*op)
default:break;
std::cout << P1;
int main()
Thanks,
Zhanghong Tang
- [cgal-discuss] copying 2D surface embedded in 3D domain, moogroo, 09/13/2012
- Re: [cgal-discuss] copying 2D surface embedded in 3D domain, Philipp Moeller, 09/13/2012
- [cgal-discuss] Error in CGAL bool operation, Zhanghong Tang, 09/14/2012
- RE: [cgal-discuss] Error in CGAL bool operation, Zhanghong Tang, 09/14/2012
