- To: <>
- Subject: RE: [cgal-discuss] How to mesh and refine the domains defined by polyhedrons?
- Date: Tue, 18 Sep 2012 01:00:43 +1200
- Importance: Normal
Dear Dr. Yvinec,
Could you please give me a small example to do this?
For example, I have two domains: a sphere outside with radius 2 and a cubit inside with edge length 2, how to define the domains and mesh these domains?
I have tried to mesh a domain by an OFF file, but it crashed.
Thanks,
Zhanghong Tang
The code is as follows:
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Polyhedral_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/refine_mesh_3.h>
#include "math.h"
#include <iostream>
#include <istream>
#include <fstream>
using namespace std;
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Simple_cartesian<double> sKernel;
typedef Kernel::Point_3 Point_3;
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::HalfedgeDS HalfedgeDS;
typedef Kernel::Plane_3 Plane_3;
typedef Polyhedron::Vertex_iterator Vertex_iterator;
typedef Polyhedron::Facet_iterator Facet_iterator;
typedef Polyhedron::Halfedge_around_facet_circulator Halfedge_facet_circulator;
typedef Nef_polyhedron::Aff_transformation_3 Aff_transformation_3;
typedef Nef_polyhedron::Vector_3 Vector_3;
// Domain
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Polyhedron_3<K> Polyhedron3;
typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron3, K> Mesh_domain;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
// To avoid verbose function and named parameters call
using namespace CGAL::parameters;
Polyhedron3 polyhedron;
std::ifstream input("a1.off");
input >> polyhedron;
Mesh_domain domain(polyhedron);
// Mesh criteria (no cell_size set)
Mesh_criteria criteria(facet_angle=25, facet_size=0.15, facet_distance=0.008,
cell_radius_edge_ratio=3);
// Mesh generation
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, no_perturb(), no_exude());
// Output
std::ofstream medit_file("out_1.mesh");
c3t3.output_to_medit(medit_file);
medit_file.close();
// Set tetrahedron size (keep cell_radius_edge_ratio), ignore facets
Mesh_criteria new_criteria(cell_radius_edge_ratio=3, cell_size=0.03);
// Mesh refinement
CGAL::refine_mesh_3(c3t3, domain, new_criteria);
// Output
medit_file.open("out_2.mesh");
Date: Mon, 17 Sep 2012 14:08:03 +0200
To:
Subject: Re: [cgal-discuss] How to mesh and refine the domains defined by polyhedrons?
you mai provide your domain as an implicit domain
CGAL::Implicit_mesh_domain_3<Function,BGT>
you will have to use
CGAL::Mesh_domain_with_polyline_features_3<MeshDomain_3>
if you wish to have the edges of the cube represented by the mesh
Thanks,
Zhanghong Tang
#include "math.h"
#include <iostream>
#include <istream>
#include <fstream>
// Domain
// Triangulation
// Criteria
// Mesh generation
// Output
medit_file.close();
// Mesh refinement
// Output
To:
Le 15/09/12 05:30, Zhanghong Tang a
écrit :
Dear all,
I plan to mesh and refine the domains defined by polyhedrons. Different domains maybe contact each other so there are some common facets in different polyhedrons (they are formed by bool operations). Could anyone give me some hints or examples on how to work on it? For example, I have two domains: a sphere outside with radius 2 and a cubit inside with edge length 2, how to define the domains and mesh these domains?
Thanks,
Zhanghong Tang
-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis
- [cgal-discuss] How to mesh and refine the domains defined by polyhedrons?, Zhanghong Tang, 09/15/2012
- Re: [cgal-discuss] How to mesh and refine the domains defined by polyhedrons?, Mariette Yvinec, 09/17/2012
- RE: [cgal-discuss] How to mesh and refine the domains defined by polyhedrons?, Zhanghong Tang, 09/17/2012
