[cgal-discuss] precorditions failure on joining 3 polygon_2s with 4 vertices each
- To:
- Subject: [cgal-discuss] precorditions failure on joining 3 polygon_2s with 4 vertices each
- Date: Thu, 20 Sep 2012 02:40:55 -0700 (PDT)
Hello,
I'm not sure if I'm doing something wrong, but I am getting precondition
failures on attempting to join 4 different simple polygons with 4 vertices
each. I'm attaching the code to reproduce (must compile in debug mode) and a
visual representation of the four polygons. They are being joined as part of
a polygon set.
With CGAL 3.9 (Ubuntu 12.04) I get:
terminate called after throwing an instance of
'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: cv.is_in_x_range (p)
File: /usr/include/CGAL/Arr_segment_traits_2.h
Line: 487
With CGAL 4.0 (Arch linux) I get:
Expr: comp_f(object, parentP->object) != SMALLER
File: /usr/include/CGAL/Multiset.h
Line: 2128
So my main question is, am I doing something wrong? I was under the
impression that the join should work. This is part of a larger framework
that works on many other cases but seems to fail in this particular one. The
code for the minimal reproduction case is very simple as can be seen.
Thanks,
Edgar
poly_precond.cpp
<http://cgal-discuss.949826.n4.nabble.com/file/n4655881/poly_precond.cpp>
<http://cgal-discuss.949826.n4.nabble.com/file/n4655881/polygons.png>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/precorditions-failure-on-joining-3-polygon-2s-with-4-vertices-each-tp4655881.html
- [cgal-discuss] precorditions failure on joining 3 polygon_2s with 4 vertices each, bobbens, 09/20/2012
- Re: [cgal-discuss] precorditions failure on joining 3 polygon_2s with 4 vertices each, Efi Fogel, 09/23/2012
- Re: [cgal-discuss] precorditions failure on joining 3 polygon_2s with 4 vertices each, Edgar Simo-Serra, 09/24/2012
