- To:
- Subject: Re: [cgal-discuss] No 2D periodic triangulations?
- Date: Fri, 21 Sep 2012 09:55:49 +0200
Le 21/09/12 09:50, Daniel Duque a écrit :
On Thursday 20 September 2012 21:59:54 gredner wrote:
Hi folks,
I've been a happy user of CGAL's 2D Delaunay triangulation code for some
time. However, I'm now in need of code for creating 2D *periodic*
triangulations, and I was very surprised to find that CGAL supports such
constructions in 3D but not in 2D! So I'm wondering:
Afaik, currently have to implement a 3D periodic triangulation with all of
your points on one plane. It's a waste of space, I know.
Indeed, it is a waste of space, and of time as well: if you use the 3D periodic triangulation for points that all lie in a plane, then you are in a 'bad' case when you can never stop computing in the 27-sheeted covering space.
So, you always compute with 27 copies of each point...
Also, using the dummy points in this very specific case would have bad effects on the resulting triangulation.
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] No 2D periodic triangulations?, gredner, 09/20/2012
- Re: [cgal-discuss] No 2D periodic triangulations?, Daniel Duque, 09/21/2012
- Re: [cgal-discuss] No 2D periodic triangulations?, Monique Teillaud, 09/21/2012
