cgal-discuss - Re: [cgal-discuss] Changing a regular triangulation
  • To:
  • Subject: Re: [cgal-discuss] Changing a regular triangulation
  • Date: Mon, 24 Sep 2012 15:38:39 -0400
Hi Olivier,
Do you know why this does not work -- was trying your suggestion:
C3t3 tmp_c3t3; // Code from refine_mesh
std::for_each(c3t3.triangulation().finite_vertices_begin(),
c3t3.triangulation().finite_vertices_end(),
CGAL::details::Insert_vertex_in_c3t3<C3t3>(tmp_c3t3));
c3t3.swap(tmp_c3t3);
// now there are no tetrahedrons in c3t3?
Thanks,
--Ram
On Mon, Sep 24, 2012 at 3:42 AM, Olivier Devillers
wrote:
> Le 9/23/12 5:26 PM, David Arken a écrit :
>> What is the fastest way to convert a regular triangulation with
>> weights on points to another regular triangulation with all weights
>> zero. I hope that this will guarantee that the regular triangulation
>> is indeed a delaunay triangulation.
>> Thanks,
> compute the Delaunay triangulation of the unweighted points !
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
