- To: Hamid G <>
- Cc: "" <>
- Subject: Re: [cgal-discuss] make_mesh_3 sub-domain not meshed
- Date: Fri, 28 Sep 2012 18:15:01 +0200
Sure,
I have attached a file with my code. You can ignore the types in the "mitk" namespace, or replace them with CGAL types where appropriate.
In my case, I have a labelled image as the input for the CGAL mesher for which I can provide a mapping of labels to a sampling distance for the seed points (the SeedPointDistanceToLabelMap type in the attached code). So for example I know that my image contains three labels, with consecutive values from 1 to 3. For value 1 I need a sampling distance of 15mm (for example), for value 2 5mm, etc. I then simply iterate over all different sampling distances and for each distance, I iterate over the whole image (with stepping according to the current distance) and create a seed point if the current image value corresponds to a label value for which that sampling distance is required.
The created seed points are then inserted into the triangluation object of my domain (instead of relying on the default constructed seed points in make_mesh_3). I'm not sure if that approach has any disadvantages (apart from brute force iterating over the image) but it seems to work okay.
- Sascha
On 09/28/2012 05:47 PM, Hamid G wrote:
Sascha,
Would you mind elaborating on what exactly you did? I have same
problem and using varying sizing field didn't help me either.
thanks in advance,
On Mon, Sep 17, 2012 at 3:37 PM, Sascha Zelzer
wrote:
Hi,
I was finally able to construct a suitable set of seed points and run the
mesh generation step successfully.
Many thanks for your hints!
Before my first posting to this list, I have tried using a CGAL::SizingField
and setting different values for the tet radii for the different
sub-domains. That did obviously not work out and I now know it is because of
an inappropriate default seed point set.
Thanks,
Sascha
On 09/10/2012 09:57 AM, Mariette Yvinec wrote:
Currently,
the best way to ensure that small component are mot missed
is to set initial points in them or on them boundary.
Then you have to use refine_mesh_3 instead of
make_mesh_3 for your initaial seeding points to be taken into account.
Another way, if you know the area where the small components are supposed to
be,
is to define a variable sizing field with a value locally similar to the
size of the components
to be meshed.
Le 30/08/12 16:18, Sascha Zelzer a écrit :
Hi,
I have posted about my problem already here
http://cgal-discuss.949826.n4.nabble.com/3D-volume-mesher-ignoring-small-subdomains-td4655756.html
but thought I reformulate it:
I have a labeled image as input to make_mesh_3 which contains a small
sub-domain (label 2) inside a larger domain (label 1). Small meaning the its
characteristic size is about two orders of magnitude smaller then the
embedding domain.
So my question is, what are the criteria for refining cells in the large
domain to ensure that they do not "shadow" a complete small sub-domain? I
would like to be able to set a large maximum cell size for the large domain
and a suitable cell size for small sub-domain. When setting the cell and
facet criteria in such a way, my small sub-domain is ignored however.
Any tips would be highly appreciated.
Thanks,
Sascha
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
template<typename MeshDomain, typename OutputIterator> void mitk::LabeledImageToTetrahedralGridFilter::ConstructSeedPoints(const mitk::Image* image, const MeshDomain* domain, const SeedPointDistanceToLabelsMap& lengths, OutputIterator pts) { typedef typename MeshDomain::Point_3 PointType; mitk::Point3D origin = image->GetGeometry()->GetOrigin(); mitk::Point3D endPoint = image->GetGeometry()->GetCornerPoint(7); for (SeedPointDistanceToLabelsMap::const_iterator iter = lengths.begin(); iter != lengths.end(); ++iter) { const std::set<mitk::LabeledImageToTetrahedralGridFilter::LabelType>& labels = iter->second; int xCount = (endPoint[0] - origin[0]) / iter->first; std::vector<std::vector<std::pair<mitk::Point3D,mitk::LabeledImageToTetrahedralGridFilter::LabelType> > > seedPoints(omp_get_max_threads()); for (std::size_t i = 0; i < seedPoints.size(); ++i) { seedPoints[i].reserve(1000); } #pragma omp parallel for for (int i = 0; i < xCount; ++i) { mitk::Point3D seedPointCandidate = origin; seedPointCandidate[0] = origin[0] + i * iter->first; while (seedPointCandidate[1] < endPoint[1]) { seedPointCandidate[2] = origin[2]; while (seedPointCandidate[2] < endPoint[2]) { mitk::LabeledImageToTetrahedralGridFilter::LabelType label = const_cast<mitk::Image*>(image)->GetPixelValueByWorldCoordinate(seedPointCandidate); if (label != 0 && labels.find(label) != labels.end()) { seedPoints[omp_get_thread_num()].push_back(std::make_pair(seedPointCandidate, label)); } seedPointCandidate[2] += iter->first; } seedPointCandidate[1] += iter->first; } } for (std::size_t i = 0; i < seedPoints.size(); ++i) { for (std::size_t j = 0; j < seedPoints[i].size(); ++j) { const mitk::Point3D& seedPoint = seedPoints[i][j].first; *pts++ = std::make_pair(PointType(seedPoint[0], seedPoint[1], seedPoint[2]), domain->index_from_subdomain_index(seedPoints[i][j].second)); } } } } vtkUnstructuredGrid* mitk::LabeledImageToTetrahedralGridFilter::GenerateUnstructuredGridFromImage(const mitk::Image* mitkImage) { typedef mitk::CGALLabeledImage_3 CGALImage; CGALImage image(mitkImage); typedef CGAL::Labeled_image_mesh_domain_3<CGALImage, CGAL::Exact_predicates_inexact_constructions_kernel> MeshDomain; MeshDomain domain(image); typedef CGAL::Mesh_triangulation_3<MeshDomain>::type Tr; typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3; typedef CGAL::Mesh_criteria_3<Tr> MeshCriteria; typedef CGAL::Mesh_constant_domain_field_3<MeshDomain::R, MeshDomain::Index> SizingField; typedef MeshCriteria::Facet_criteria FacetCriteria; typedef MeshCriteria::Cell_criteria CellCriteria; SizingField cellRadii(m_CellSize); for (std::map<LabelType,float>::iterator i = m_LabelToCellSize.begin(); i != m_LabelToCellSize.end(); ++i) { cellRadii.set_size(i->second, 3, domain.index_from_subdomain_index(i->first)); } SizingField facetRadii(m_FacetSize); for (std::map<LabelType,float>::iterator i = m_LabelToFacetSize.begin(); i != m_LabelToFacetSize.end(); ++i) { facetRadii.set_size(i->second, 3, domain.index_from_subdomain_index(i->first)); } FacetCriteria facet_crit( m_FacetAngle, // angle facetRadii, // size m_FacetDistance); // approximation CellCriteria cell_crit( m_CellRadiusEdgeRatio, // radius-edge ratio cellRadii); // size MeshCriteria mesh_crit(facet_crit, cell_crit); // Initialize c3t3 C3t3 c3t3; typedef MeshDomain::Point_3 Point_3; typedef MeshDomain::Index Index; typedef std::vector<std::pair<Point_3, Index> > Initial_points_vector; typedef typename Initial_points_vector::iterator Ipv_iterator; typedef typename C3t3::Vertex_handle Vertex_handle; // Mesh initialization : get some points and add them to the mesh Initial_points_vector initial_points; int pointDimension = 3; this->ConstructSeedPoints(mitkImage, &domain, m_SeedPointDistanceToLabels, std::back_inserter(initial_points)); if (initial_points.empty()) { domain.construct_initial_points_object()(std::back_inserter(initial_points)); pointDimension = 2; } // Insert points and set their index and dimension for ( Ipv_iterator it = initial_points.begin() ; it != initial_points.end() ; ++it ) { Vertex_handle v = c3t3.triangulation().insert(it->first); // v could be null if point is hidden if ( v != Vertex_handle() ) { c3t3.set_dimension(v, pointDimension); c3t3.set_index(v, it->second); } } CGAL_assertion( c3t3.triangulation().dimension() == 3 ); // Build mesher and launch refinement process // Don't reset c3t3 as we just created it CGAL::refine_mesh_3(c3t3, domain, mesh_crit, CGAL::parameters::no_reset_c3t3()); vtkUnstructuredGrid* vtkUG = mitk::CGALMeshUtil::CGALMeshToVtk(c3t3); return vtkUG; }
- Re: [cgal-discuss] make_mesh_3 sub-domain not meshed, Mariette Yvinec, 09/10/2012
- Re: [cgal-discuss] make_mesh_3 sub-domain not meshed, Sascha Zelzer, 09/17/2012
- Re: [cgal-discuss] make_mesh_3 sub-domain not meshed, Hamid G, 09/28/2012
- Re: [cgal-discuss] make_mesh_3 sub-domain not meshed, Sascha Zelzer, 09/28/2012
