- To:
- Subject: Re: [cgal-discuss] Simple chains from a list of vertices
- Date: Sat, 29 Sep 2012 17:00:54 +0200
David Canino
writes:
> Good morning,
> I am a very beginner user of CGAL. I am trying to construct simple chains
> from a list of 2D/3D points (at least, but of arbitrary dimension,
> possibly). Basically, I am sure that such points are planar, but their
> order does not necessarily impose a simple chain. My objective is to form
> simple polygons from their list of points. I am able to do this through the
> convex hull in CGAL, but in this way I discard cases where the input
> polygon is not convex. Any idea to do this in CGAL?
You can probably use Alpha Shapes [1][2] to extract your input shape.
There is also the concept of a Characteristic Hull, but AFAIK no code
for that in CGAL.
Footnotes:
[1]
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_2/Chapter_main.html
[2]
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html
- [cgal-discuss] Simple chains from a list of vertices, David Canino, 09/29/2012
- Re: [cgal-discuss] Simple chains from a list of vertices, Philipp Moeller, 09/29/2012
