cgal-discuss - Re: [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon
  • To:
  • Subject: Re: [cgal-discuss] Re: Bug? with boundary condition when creating exterior offset polygon
  • Date: Tue, 02 Oct 2012 12:08:18 +0200
On 09/17/2012 07:19 AM, Nigel Drego wrote:
Sebastien,
Thanks for confirming the problem. Any luck with a fix/solution?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-with-boundary-condition-when-creating-exterior-offset-polygon-tp4655843p4655867.html
Can you try with the attached patched file (CGAL/Straight_skeleton_2/Polygon_offset_builder_2_impl.h) ?
Thanks,
Sebastien.
// Copyright (c) 2005, 2006 Fernando Luis Cacciola Carballal. All rights reserved.
// This file is part of CGAL (www.cgal.org).
// You can redistribute it and/or modify it under the terms of the GNU
// General Public License as published by the Free Software Foundation,
// either version 3 of the License, or (at your option) any later version.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: svn+ssh:///svn/cgal/branches/next/Straight_skeleton_2/include/CGAL/Straight_skeleton_2/Polygon_offset_builder_2_impl.h $
// $Id: Polygon_offset_builder_2_impl.h 67117 2012-01-13 18:14:48Z lrineau $
// Author(s)     : Fernando Cacciola <>
#ifndef CGAL_POLYGON_OFFSET_BUILDER_2_IMPL_H
#define CGAL_POLYGON_OFFSET_BUILDER_2_IMPL_H 1
namespace CGAL {
template<class Ss, class Gt, class Cont, class Visitor>
Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::Polygon_offset_builder_2( Ss const& aSs, Traits const& aTraits, Visitor const& aVisitor )
   mTraits (aTraits)
  ,mVisitor(aVisitor)
  int lMaxID = -1 ;
  for ( Halfedge_const_handle lHE = aSs.halfedges_begin() ; lHE != aSs.halfedges_end() ; ++ lHE )
    if ( lHE->id() > lMaxID )
      lMaxID = lHE->id() ;
    if ( !lHE->is_bisector() && handle_assigned(lHE->face()) )
      mBorders.push_back(lHE);
  CGAL_POLYOFFSET_TRACE(2, "Border count: " << mBorders.size() ) ;
  CGAL_POLYOFFSET_TRACE(2, "Highest Bisector ID: " << lMaxID ) ;
  mBisectorData.resize(lMaxID+1);
  ResetBisectorData();
typename Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::Halfedge_const_handle
Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::LocateHook( FT                    aTime
                                                        , Halfedge_const_handle aBisector
                                                        , bool                  aIncludeLastBisector
                                                        , Hook_position&        rPos
  CGAL_POLYOFFSET_TRACE(2,"Searching for hook at " << aTime ) ;
  Halfedge_const_handle rHook ;
  while ( aBisector->is_bisector() && ( aIncludeLastBisector ? true : aBisector->prev()->is_bisector() ) )
    Halfedge_const_handle lPrev = aBisector->prev();
    Halfedge_const_handle lNext = aBisector->next();
    CGAL_POLYOFFSET_TRACE(2,"Testing hook on " << e2str(*aBisector) ) ;
    CGAL_POLYOFFSET_TRACE(4, "Next: " << e2str(*lNext) << " - Prev: " << e2str(*lPrev) ) ;
    if ( !IsVisited(aBisector) )
      if ( aBisector->slope() != ZERO )
        // A hook is found here if 'aTime' is within the bisector time interval.
        // Depending on the bisector slope, src-time might be smaller or larger than tgt-time,
        // so the test is:
        //  (src-time <= time <= tgt-time ) || ( tgt-time <= time <= src-time )
        Comparison_result lTimeWrtSrcTime = lPrev->is_bisector() ? Compare_offset_against_event_time(aTime,lPrev    ->vertex()) : LARGER ;
        Comparison_result lTimeWrtTgtTime = lNext->is_bisector() ? Compare_offset_against_event_time(aTime,aBisector->vertex()) : LARGER ;
        CGAL_POLYOFFSET_TRACE(3,"  TimeWrtSrcTime: " << lTimeWrtSrcTime << " TimeWrtTgtTime: " << lTimeWrtTgtTime ) ;
        // The above test expressed in terms of comparisons of src/tgt time against aTime is:
        // (     ( time-wrt-src-time == ZERO || time-wrt-src-time == SMALLER )
        //    && ( time-wrt-tgt-time == ZERO || time-wrt-tgt-time == LARGER  )
        // || -the same with src/tgt inverted-
        // (      ( time-wrt-tgt-time == ZERO || time-wrt-tgt-time == SMALLER )
        //     && ( time-wrt-src-time == ZERO || time-wrt-src-time == LARGER  )
        // But since bisectors of slope zero are skipped, both comparisons cannot be zero, thus, the test above is really:
        //    ( ( time-wrt-src-time == ZERO || time-wrt-src-time == SMALLER )  && (                              time-wrt-tgt-time == LARGER ) )
        // || ( (                              time-wrt-src-time == SMALLER )  && ( time-wrt-tgt-time == ZERO || time-wrt-tgt-time == LARGER ) )
        // || ( ( time-wrt-tgt-time == ZERO || time-wrt-tgt-time == SMALLER )  && (                              time-wrt-src-time == LARGER ) )
        // || ( (                              time-wrt-tgt-time == SMALLER )  && ( time-wrt-src-time == ZERO || time-wrt-src-time == LARGER ) )
        // Which actually boils down to this:
        if ( lTimeWrtSrcTime != lTimeWrtTgtTime )
          CGAL_stskel_intrinsic_test_assertion( !CGAL_SS_i::is_time_clearly_not_within_possibly_inexact_bisector_time_interval(aTime,aBisector) ) ;
          bool lLocalPeak = false ;
          if ( aBisector->slope() == POSITIVE && lTimeWrtSrcTime == EQUAL )
            while ( lPrev->is_bisector() && ( lPrev->slope() == ZERO ) )
             lPrev = lPrev->prev();
            lLocalPeak = ( lPrev->slope() == NEGATIVE ) ;
          if ( !lLocalPeak )
            rPos = ( lTimeWrtTgtTime == EQUAL ? TARGET : lTimeWrtSrcTime == EQUAL ? SOURCE : INSIDE ) ;
            rHook = aBisector ;
            CGAL_POLYOFFSET_TRACE(2, "  Hook found here at " << Hook_position2Str(rPos) ) ;
            break ;
          else
            CGAL_POLYOFFSET_TRACE(2, "  Hook found here local peak. Ignored." ) ;
        else
          CGAL_stskel_intrinsic_test_assertion( !CGAL_SS_i::is_time_clearly_within_possibly_inexact_bisector_time_interval(aTime,aBisector) ) ;
          CGAL_POLYOFFSET_TRACE(2, "  Hook not found here.") ;
      else
        CGAL_POLYOFFSET_TRACE(2,"Bisector is a roof peak.");
    else
      CGAL_POLYOFFSET_TRACE(2,"Bisector already visited");
    aBisector = lPrev ;
  return rHook;
Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::LocateSeed( FT aTime, Halfedge_const_handle aBorder )
  CGAL_POLYOFFSET_TRACE(2,"\nLocating seed for face " << e2str(*aBorder) ) ;
  Hook_position lPos ;
  Halfedge_const_handle rSeed = LocateHook(aTime,aBorder->prev(),false,lPos);
  if ( handle_assigned(rSeed) )
    if ( !IsUsedSeed(rSeed) )
      SetIsUsedSeed(rSeed);
      CGAL_postcondition( rSeed->prev()->is_bisector() ) ;
      // If a seed hook is found right at a bisector source,
      // the next hook will be found right at the prev bisector's target, which would be a mistake,
      // so we ajust the seed as the (target) of the prev
      if ( lPos == SOURCE )
        rSeed = rSeed->prev() ;
    else
      CGAL_POLYOFFSET_TRACE(2,"Seed already used. Discarded");
      rSeed = Halfedge_const_handle();
  return rSeed ;
Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::LocateSeed( FT aTime )
  CGAL_POLYOFFSET_TRACE(2,"Searching for seed at " << aTime ) ;
  Halfedge_const_handle rSeed ;
  for ( typename Halfedge_vector::const_iterator f = mBorders.begin()
       ; f != mBorders.end() && !handle_assigned(rSeed)
       ; ++ f
    rSeed = LocateSeed(aTime,*f);
  CGAL_POLYOFFSET_TRACE(2,"Seed:" << eh2str(rSeed) ) ;
  return rSeed;
void Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::AddOffsetVertex( FT                    aTime
        , Halfedge_const_handle aHook
        , ContainerPtr          aPoly
  Visit(aHook);
  OptionalPoint_2 lP = Construct_offset_point(aTime,aHook);
  if ( !lP )
    lP = mVisitor.on_offset_point_overflowed(aHook) ;
  CGAL_postcondition(lP);
  CGAL_POLYOFFSET_TRACE(1,"Found offset point p=" << p2str(*lP) << " at offset " << aTime << " along bisector " << e2str(*aHook) << " reaching " << v2str(*aHook->vertex()) ) ;
  mVisitor.on_offset_point(*lP);
  if ( lP != mLastPoint )
    aPoly->push_back(*lP);
    mLastPoint = lP ;
  else
    CGAL_POLYOFFSET_TRACE(1,"Duplicate point. Ignored");
  CGAL_POLYOFFSET_DEBUG_CODE( ++ mStepID ) ;
template<class OutputIterator>
OutputIterator Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::TraceOffsetPolygon( FT aTime, Halfedge_const_handle aSeed, OutputIterator aOut )
  CGAL_POLYOFFSET_TRACE(1,"\nTracing new offset polygon" ) ;
  ContainerPtr lPoly( new Container() ) ;
  mVisitor.on_offset_contour_started();
  Halfedge_const_handle lHook = aSeed ;
std::vector <Halfedge_const_handle > visited_hooks;
  do
    CGAL_POLYOFFSET_TRACE(1,"STEP " << mStepID ) ;
    Halfedge_const_handle lLastHook = lHook ;
    lHook = LocateHook(aTime,lHook->prev(),true,lPos) ;
    Visit(lLastHook);
    if ( handle_assigned(lHook) )
      AddOffsetVertex(aTime,lHook, lPoly);
      CGAL_POLYOFFSET_TRACE(1,"B" << lLastHook->id() << " and B" << lHook->id() << " visited." ) ;
      lHook = lHook->opposite();
      visited_hooks.push_back(lLastHook);
  while ( handle_assigned(lHook) && lHook != aSeed  && !IsVisited(lHook)) ;
  bool lComplete = ( lHook == aSeed )  ;
  CGAL_POLYOFFSET_TRACE(1,"Offset polygon of " << lPoly->size() << " vertices traced." << ( lComplete ? "COMPLETE" : "INCOMPLETE" ) ) ;
  CGAL_assertion ( !lComplete || ( lComplete && lPoly->size() >= 3 ) ) ;
  mVisitor.on_offset_contour_finished( lComplete );
  if ( lComplete )
    *aOut++ = lPoly ;
  else
    for (std::size_t k=0;k<visited_hooks.size();++k)
      GetBisectorData( visited_hooks[k] ).IsVisited=false;
  return aOut ;
void Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::ResetBisectorData()
  std::fill(mBisectorData.begin(),mBisectorData.end(), Bisector_data() );
OutputIterator Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::construct_offset_contours( FT aTime, OutputIterator aOut )
  CGAL_precondition( aTime > static_cast<FT>(0.0) ) ;
  CGAL_POLYOFFSET_DEBUG_CODE( mStepID = 0 ) ;
  mVisitor.on_construction_started(aTime);
  mLastPoint = boost::none ;
  CGAL_POLYOFFSET_TRACE(1,"Constructing offset polygons for offset: " << aTime ) ;
  for ( Halfedge_const_handle lSeed = LocateSeed(aTime); handle_assigned(lSeed); lSeed = LocateSeed(aTime) )
    aOut = TraceOffsetPolygon(aTime,lSeed,aOut);
  mVisitor.on_construction_finished();
  return aOut ;
typename Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::Trisegment_2_ptr
Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::CreateTrisegment ( Vertex_const_handle aNode ) const
  CGAL_precondition(handle_assigned(aNode));
  Trisegment_2_ptr r ;
  CGAL_POLYOFFSET_TRACE(3,"Creating Trisegment for " << v2str(*aNode) ) ;
  if ( aNode->is_skeleton() )
    Triedge const& lEventTriedge =  aNode->event_triedge() ;
    r = CreateTrisegment(lEventTriedge) ;
      !CGAL_SS_i::is_possibly_inexact_distance_clearly_not_equal_to( Construct_ss_event_time_and_point_2(mTraits)(r)->get<0>()
        , aNode->time()
    CGAL_POLYOFFSET_TRACE(3,"Event triedge=" << lEventTriedge ) ;
    if ( r->degenerate_seed_id() == Trisegment_2::LEFT )
     CGAL_POLYOFFSET_TRACE(3,"Left seed is degenerate." ) ;
      Vertex_const_handle lLeftSeed = GetSeedVertex(aNode
                                                   ,aNode->primary_bisector()->prev()->opposite()
                                                   ,lEventTriedge.e0()
                                                   ,lEventTriedge.e1()
      if ( handle_assigned(lLeftSeed) )
        r->set_child_l( CreateTrisegment(lLeftSeed) ) ; // Recursive call
    else if ( ! aNode->is_split() && r->degenerate_seed_id() == Trisegment_2::RIGHT )
      CGAL_POLYOFFSET_TRACE(3,"Right seed is degenerate." ) ;
      Vertex_const_handle lRightSeed = GetSeedVertex(aNode
                                                    ,aNode->primary_bisector()->opposite()->next()
                                                    ,lEventTriedge.e1()
                                                    ,lEventTriedge.e2()
      if ( handle_assigned(lRightSeed) )
        r->set_child_r( CreateTrisegment(lRightSeed) ) ; // Recursive call
  return r ;
typename Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::Vertex_const_handle
Polygon_offset_builder_2<Ss,Gt,Cont,Visitor>::GetSeedVertex ( Vertex_const_handle   aNode
                                                            , Halfedge_const_handle aEa
                                                            , Halfedge_const_handle aEb
                                                            ) const
  Vertex_const_handle rSeed ;
  if ( Is_bisector_defined_by(aBisector,aEa,aEb) )
    rSeed = aBisector->vertex();
    CGAL_POLYOFFSET_TRACE(3,"Seed of N" << aNode->id() << " for vertex (E" << aEa->id() << ",E" << aEb->id() << ") directly found: V" << rSeed->id() ) ;
  else
    typedef typename Vertex::Halfedge_around_vertex_const_circulator Halfedge_around_vertex_const_circulator ;
    Halfedge_around_vertex_const_circulator cb = aNode->halfedge_around_vertex_begin() ;
    Halfedge_around_vertex_const_circulator c  = cb ;
    do
      Halfedge_const_handle lBisector = *c ;
      if ( Is_bisector_defined_by(lBisector,aEa,aEb) )
        rSeed = lBisector->opposite()->vertex();
        CGAL_POLYOFFSET_TRACE(3,"Seed of N" << aNode->id() << " for vertex (E" << aEa->id() << ",E" << aEb->id() << ") indirectly found: V" << rSeed->id() ) ;
    while ( !handle_assigned(rSeed) && ++ c != cb ) ;
  return rSeed ;
} // end namespace CGAL
#endif // CGAL_POLYGON_OFFSET_BUILDER_2_IMPL_H //
// EOF //
