cgal-discuss - Re: [cgal-discuss] squared_distance performance
  • To:
  • Subject: Re: [cgal-discuss] squared_distance performance
  • Date: Wed, 03 Oct 2012 22:47:47 +0200
Could you post the code you used for the benchmark?
On which platform are you running this test (OS, compiler, flags, optimisations...)
Thanks,
Sebastien.
On 10/03/2012 09:47 PM, topotun wrote:
Hello everyone.
I am trying to get a feel for the performance of the CGAL's AABB-based
distance computation routines (/squared_distance/, /closest_point/,
/closest_point_and_primitive/), using the corresponding tutorial in the
online manual. Currently I am simply loading some .off files found on the
web for the polyhedron model and compute distance to the polyhedron from
random points in space.
What I am seeing is that the /squared_distance /is at least two orders of
magnitude slower than either the /closest_point /or
/closest_point_and_primitive /(e.g., ~32ms versus 0.56ms/0.57ms). This
behavior remains consistent for all .off models I have tried. This seems to
contradict the results posted on the CGAL manual page, where all three of
these functions exhibited approximately the same performance. Furthermore,
calling the /accelerate_distance_queries /after the tree is constructed
actually decreases the performance by about half, thus making me question
its functionality.
The timing is done very simply with the OpenMP’s /omp_get_wtime(), /which
might not be the most accurate method, but does allow me to come up with the
aforementioned questions.
Any advice on this matter will be greatly appreciated.
Denis
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/squared-distance-performance-tp4655960.html
