- To: Hamid G <>
- Cc: "" <>
- Subject: Re: [cgal-discuss] make_mesh_3 sub-domain not meshed
- Date: Thu, 04 Oct 2012 20:14:10 +0200
Hi,
I don't know. I would have thought that the optimization step is allowed to modify the position of the initial seed points. Contrary to 1D features for example.
- Sascha
On 10/02/2012 07:35 PM, Hamid G wrote:
Thanks Sascha, this was a great help.
Do you know if the seeded points are going to be preserved in the mesh
or they are just temporary guides for the meshing algorithm?
On Fri, Sep 28, 2012 at 12:15 PM, Sascha Zelzer
wrote:
Sure,
I have attached a file with my code. You can ignore the types in the "mitk"
namespace, or replace them with CGAL types where appropriate.
In my case, I have a labelled image as the input for the CGAL mesher for
which I can provide a mapping of labels to a sampling distance for the seed
points (the SeedPointDistanceToLabelMap type in the attached code). So for
example I know that my image contains three labels, with consecutive values
from 1 to 3. For value 1 I need a sampling distance of 15mm (for example),
for value 2 5mm, etc. I then simply iterate over all different sampling
distances and for each distance, I iterate over the whole image (with
stepping according to the current distance) and create a seed point if the
current image value corresponds to a label value for which that sampling
distance is required.
The created seed points are then inserted into the triangluation object of
my domain (instead of relying on the default constructed seed points in
make_mesh_3). I'm not sure if that approach has any disadvantages (apart
from brute force iterating over the image) but it seems to work okay.
- Sascha
On 09/28/2012 05:47 PM, Hamid G wrote:
Sascha,
Would you mind elaborating on what exactly you did? I have same
problem and using varying sizing field didn't help me either.
thanks in advance,
On Mon, Sep 17, 2012 at 3:37 PM, Sascha Zelzer
wrote:
Hi,
I was finally able to construct a suitable set of seed points and run the
mesh generation step successfully.
Many thanks for your hints!
Before my first posting to this list, I have tried using a
CGAL::SizingField
and setting different values for the tet radii for the different
sub-domains. That did obviously not work out and I now know it is because
of
an inappropriate default seed point set.
Thanks,
Sascha
On 09/10/2012 09:57 AM, Mariette Yvinec wrote:
Currently,
the best way to ensure that small component are mot missed
is to set initial points in them or on them boundary.
Then you have to use refine_mesh_3 instead of
make_mesh_3 for your initaial seeding points to be taken into account.
Another way, if you know the area where the small components are supposed
to
be,
is to define a variable sizing field with a value locally similar to the
size of the components
to be meshed.
Le 30/08/12 16:18, Sascha Zelzer a écrit :
Hi,
I have posted about my problem already here
http://cgal-discuss.949826.n4.nabble.com/3D-volume-mesher-ignoring-small-subdomains-td4655756.html
but thought I reformulate it:
I have a labeled image as input to make_mesh_3 which contains a small
sub-domain (label 2) inside a larger domain (label 1). Small meaning the
its
characteristic size is about two orders of magnitude smaller then the
embedding domain.
So my question is, what are the criteria for refining cells in the large
domain to ensure that they do not "shadow" a complete small sub-domain? I
would like to be able to set a large maximum cell size for the large
domain
and a suitable cell size for small sub-domain. When setting the cell and
facet criteria in such a way, my small sub-domain is ignored however.
Any tips would be highly appreciated.
Thanks,
Sascha
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- Re: [cgal-discuss] make_mesh_3 sub-domain not meshed, Hamid G, 10/02/2012
- Re: [cgal-discuss] make_mesh_3 sub-domain not meshed, Sascha Zelzer, 10/04/2012
