[cgal-discuss] Re: how to use Image_3::labellized_trilinear_interpolation() properly
- To:
- Subject: [cgal-discuss] Re: how to use Image_3::labellized_trilinear_interpolation() properly
- Date: Wed, 10 Oct 2012 21:24:31 -0700 (PDT)
Thanks for your reply.
I am using .inr file format to pass segmented images (which are in several
.bmp files) to CGAL mesher.
The goal is to mesh a block with a tiny sub-region inclusion with different
meshing sizes.
Were you able to reproduce the bug in mesh_3D_image.cpp with:
int label = image.labellized_trilinear_interpolation(0., 0., 57., 0);
Does the class/template provide any mechanism to deduce the type of image if
we don't have prior information about the image file we are reading?
thanks again
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/how-to-use-Image-3-labellized-trilinear-interpolation-properly-tp4655999p4656005.html
- [cgal-discuss] how to use Image_3::labellized_trilinear_interpolation() properly, Hamid G, 10/09/2012
- Re: [cgal-discuss] how to use Image_3::labellized_trilinear_interpolation() properly, Laurent Rineau (CGAL/GeometryFactory), 10/10/2012
- [cgal-discuss] Re: how to use Image_3::labellized_trilinear_interpolation() properly, Hamid G, 10/11/2012
- Re: [cgal-discuss] Re: how to use Image_3::labellized_trilinear_interpolation() properly, Laurent Rineau (CGAL/GeometryFactory), 10/11/2012
