- To:
- Subject: Re: [cgal-discuss] How to cut off Voronoi diagram inside a convex hull
- Date: Fri, 12 Oct 2012 10:46:18 +0200
On 10/12/2012 09:52 AM, Wang Hetao wrote:
I want to cut a Voronoi diagram using a convex polygon and get the remainingLook at this example [1].
inside the polygon. The convex polygon is not bounding box exactly, but has
something familiar.
The illustration below is an example:
<http://cgal-discuss.949826.n4.nabble.com/file/n4656035/05%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE.png>
Thx for your reply!
You need to replace the function crop_and_extract_segment to crop to your convex polygon.
Use the package Box_intersection_d [2] for example to get the intersection points and construct the cropped segments.
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_37.5.4
[2] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d/Chapter_main.html
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-cut-off-Voronoi-diagram-inside-a-convex-hull-tp4656035.html
- [cgal-discuss] How to cut off Voronoi diagram inside a convex hull, Wang Hetao, 10/12/2012
- Re: [cgal-discuss] How to cut off Voronoi diagram inside a convex hull, Sebastien Loriot (GeometryFactory), 10/12/2012
