[cgal-discuss] c3t3 criteria question is the "radius bound" same as the "distance bound" for facet?
- To:
- Subject: [cgal-discuss] c3t3 criteria question is the "radius bound" same as the "distance bound" for facet?
- Date: Fri, 19 Oct 2012 02:16:43 -0700 (PDT)
Hi everyone,
Recently,I write a programme about the 3d mesh.I don't understand the facet
criteria "radius bound".
First question : Is the "radius bound" same as the "distance bound" for
facet?
Second question : How should I use this criteria in my programme.
In the cgal_manual , it gives
Mesh_criteria criteria(facet_angle=30, facet_size=0.1, facet_distance=0.025,
cell_radius_edge_ratio=2, cell_size=0.1);
if i choose facet_distance=0.1, facet_size=? ???
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/c3t3-criteria-question-is-the-radius-bound-same-as-the-distance-bound-for-facet-tp4656052.html
- [cgal-discuss] c3t3 criteria question is the "radius bound" same as the "distance bound" for facet?, optiker, 10/19/2012
