cgal-discuss - [cgal-discuss] Polyhedron_3 allocation on shared memory
  • To:
  • Subject: [cgal-discuss] Polyhedron_3 allocation on shared memory
  • Date: Thu, 25 Oct 2012 13:15:46 +0200 (CEST)
Hi!,
I am taking part in the development of project focused on creating high
performance data processing environment in C++ / C++11 right now on linux (but
we are planning to add other platforms in the future). Right now me and my
team are doing research in field of 3D graphics data structures.
As one of our options we are concidering CGAL as library, on which we will
base.
During the research we came across a big problem with allocating
CGAL::Polyhedron_3 on shared memory. We have searched the web for answer,
asked several questions mainly on stackoverflow, but so far, we've got no real
solution.
As short overwiew – we want to implement a mechanism allowing for sharing 3D
data structures between applications. Of course it is possible to stream
geometry to OFF format to shared memory from source application and then
stream it back in target application (like in
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Subsection_25.3.6),
but it is to slow for our purpose (double conversion) and we want to be able
to operate on CGAL's geometry inside shared memory, in such way, that
independend applications could use it as is.
Please take a look at these questions:
http://stackoverflow.com/questions/12657030/share-cgals-geometry-between-processes-in-c
http://stackoverflow.com/questions/12807616/how-to-allocate-cgals-halfedge-struture-in-shared-memory
We know, that according to the CGAL's documentation
(http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3.html#Cross_link_anchor_1110)
the allocators should be as follow:
“The fourth parameter Alloc requires a standard allocator for STL container
classes.”.
The problem is that it is impossible to use std::allocator on shared memory.
We were trying to use boost::interprocess::allocator as Polyhedron_3
allocator, but we have found out that we need stateless allocator like
std::allocator (becouse during initialization of Polyhedron_3 there is no way
to pass arguments to constructor of custom, non stateless allocator). We have
also implemented very simple class extending boost::interprocess::allocator to
make it stateless (code sample: http://pastebin.com/uJYG6AP4) The problem is
that it's working with other objects like vector but not with Polyhedron_3 (it
gives some complex compilation errors).
We would be very gratefull for any tips/solutions in this matter.
