cgal-discuss - [cgal-discuss] Problems with cgal function "Object intersection ( Type1<Kernel> obj1, Type2<Kernel> obj2) "
  • To:
  • Subject: [cgal-discuss] Problems with cgal function "Object intersection ( Type1<Kernel> obj1, Type2<Kernel> obj2) "
  • Date: Tue, 30 Oct 2012 08:18:23 -0700 (PDT)
Hello to all users,
I am using the cgal function
to find the intersection between a *Plane_3* and a *Triangle_3*, for example
with names tmpPlane and tmpTriangle.
In many examples I don't have any problem, but in some examples this
function
made exceptions like the following:
Unhandled exception at 0x778515de in MyProgram.exe: 0xC0000005: Access
violation reading location 0x00000000
I guess that there is a problem in my created tmpPlane or tmpTriangle. I
used the control tests
tmpPlane.is_degenerated()
tmpTriangle.is_degenerated()
to avoid calling the intersection function, so I can handle the exception
that is created if the tmpPlane or the tmpTriangle is degenerated.
But in some examples I still got exceptio, although the tmpPlane and the
tmpTriangle are *not* degenerated.
I want to ask if there is another test that I can add to my created plane
and triangle to avoid getting exception from intersection function?
Any help would be incredible much appreciated, cause I have a strict
deadline to finish my project.
Thank everybody in advance,
Dimitris
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-with-cgal-function-Object-intersection-Type1-Kernel-obj1-Type2-Kernel-obj2-tp4656101.html
