Re: [cgal-discuss] CGAL 4.1 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.1 Released, Computational Geometry Algorithms Library
- Date: Tue, 30 Oct 2012 18:45:49 +0100
Hi,
On 10/24/2012 04:56 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.1
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.1 are now available as well. Simply add
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian squeeze main
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian squeeze main
deb ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
deb-src ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian wheezy main
to /etc/apt/sources list (you only need the pair of lines corresponding
to the release you are using). For sid, packages should be available
from the official Debian repository in a few days. The packages are called
libcgal10, libcgal-dev, libcgal-qt4-10. libcgal-qt4-dev, libcgal-demo, and
libcgal-ipelets.
In case you want to download the packages manually, have a look at
ftp://ftp.mpi-sb.mpg.de/pub/outgoing/CGAL/debian/pool/main/c/cgal/
See also http://www.cgal.org/FAQ.html#debian_packages .
Joachim
- [cgal-discuss] CGAL 4.1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 10/24/2012
- Re: [cgal-discuss] CGAL 4.1 Released, Computational Geometry Algorithms Library, Shriramana Sharma, 10/30/2012
- Re: Re: [cgal-discuss] CGAL 4.1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 10/30/2012
- Re: [cgal-discuss] CGAL 4.1 Released, Computational Geometry Algorithms Library, Joachim Reichel, 10/30/2012
- Re: [cgal-discuss] CGAL 4.1 Released, Computational Geometry Algorithms Library, Shriramana Sharma, 10/31/2012
- Re: [cgal-discuss] CGAL 4.1 Released, Computational Geometry Algorithms Library, 刘先勇, 10/31/2012
