- To:
- Subject: Re: [cgal-discuss] polyhedron is_valid
- Date: Fri, 02 Nov 2012 00:10:11 +0100
On 11/01/2012 03:41 PM, drrk wrote:
I am reading a mesh that contains polygonal data. The mesh loads fine inIf you simply call is_valid() with no argument, it checks only if the combinatorial structure is a valid (that is the embedding is not checked).
various software such as MeshLab but when I call the is_valid() function of
Polyhedron_3<Kernel> where Kernel is Cartesian<double> it returns false.
What criteria have to be satisfied before is_valid( ) accepts a mesh to be
valid.
You have an error when the data you have is not manifold (3 facets incident to the same edge...)
If you call is_valid(true), you might get hints on the nature of the
problem.
Sebastien.
RK
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/polyhedron-is-valid-tp4656124.html
- [cgal-discuss] polyhedron is_valid, drrk, 11/01/2012
- Re: [cgal-discuss] polyhedron is_valid, Sebastien Loriot (GeometryFactory), 11/02/2012
