cgal-discuss - Re: [cgal-discuss] Re: Running CGAL under Xcode and OSX Lion
  • To:
  • Subject: Re: [cgal-discuss] Re: Running CGAL under Xcode and OSX Lion
  • Date: Sat, 03 Nov 2012 22:08:43 +0100
Eran Yanay
writes:
> thank you for your help, i guess it did help me a bit.
> I did the following:
> http://i47.tinypic.com/16iuzhg.jpg
> afterwards i compiled the code from an example, but removed the main to a
> simple print, just to see if i can compile it successfuly, so i used this
> code:
> http://i48.tinypic.com/2ca5xw.jpg
> it seems the build settings did help, but i still got this:
> http://i49.tinypic.com/ipp1ro.jpg
> Im not sure if its related to cgal or not, please help me in the process.
> thanks alot
All those errors come from libcpp and really shouldn't be there. Make
sure your XCode is up-to-date. Try to compile minimal examples using the
standard library. Otherwise look for help on an XCode/MacOS mailing
list.
