cgal-discuss - Re: [cgal-discuss] CAD model volume meshing using Mesh_3 ?
  • To:
  • Subject: Re: [cgal-discuss] CAD model volume meshing using Mesh_3 ?
  • Date: Mon, 05 Nov 2012 19:17:59 +0100
A priori, this is not possible.
the cgal mesh generation package is designed to mesh
at the same times surfaces and the 3d domain components
bounded by thoses surfaces.
Le 31/10/12 11:23, Mark Blome a écrit :
Hi all,
I have a simple question about the 3D Mesh Generation package:
Is it possible to volume discretize a domain using a triangulated surface
as input enforcing the triangulated surface not to be modified during meshing?
From mesh_polyhedral_domain.cpp (Mesh_3/applications/)I learned that I can use
    c3t3.insert_surface_points(polyhedron.points_begin(),
                               polyhedron.points_end(),
                               domain.make_surface_index());
    CGAL::refine_mesh_3<C3t3>(c3t3, domain, criteria, no_exude(), no_perturb());
to force all points of the initial polygonal surface to be present in the resulting mesh,
but would this guarantee the surface to remain unchanged in the final result ?
I would need this functionality for volume discretizing a CAD model that consists of
several solids with shared model faces and edges (I discretize faces and edges
beforehand using a different mesher).
Thanks for any help on this,
Mark
Mariette Yvinec
Geometrica project team
INRIA  Sophia-Antipolis
  • Re: [cgal-discuss] CAD model volume meshing using Mesh_3 ?, Mariette Yvinec, 11/05/2012
