- To: "cgal-discuss" <>
- Subject: 回复: [cgal-discuss] 回复: [cgal-discuss] runnig a demo in CGAL
- Date: Mon, 12 Nov 2012 14:47:10 +0800
I do not know what you said error, he said that this error vs debug error you unnecessary debugging in release。i am a beginner, hoping to get your help, the problem I encountered The cgal debug barrier, I hope you can help me. Thank you
------------------ 原始邮件 ------------------
发件人: "sara ershadi"<>;
发送时间: 2012年11月12日(星期一) 下午2:30
收件人: ""<>;
主题: Re: [cgal-discuss] 回复: [cgal-discuss] runnig a demo in CGAL
Hi ,
I explain my means with more detail now :
I want to run a demo and see the visual output.
As it is said in CGAL manual : triangulation3 demo has visual output , therefore I select it for my mean.
I used Cmake for compile and generate .sln file . It created successfully .
Then I open it with visual studio and build it . It proceed successively too.
now .exe file are created in debug folder .
When I open them , it close immediately and I saw nothing.
When I open .exe file in visuall studio I don't know what should I do .
when I debug a .exe file , it ends up with error about .PDB file .
I hope you understand my mean this time.
To: cgal-discuss <>
Sent: Sunday, November 11, 2012 10:20 PM
Subject: [cgal-discuss] 回复: [cgal-discuss] runnig a demo in CGAL
发送时间: 2012年11月12日(星期一) 下午2:17
收件人: ""<>;
主题: Re: [cgal-discuss] runnig a demo in CGAL
Thanks , I am following CGAL manual pdf. and I want to run triangulation3 demo as it said that it is visual and has visible output.
.exe file are created but pronto closed in windows and I saw nothing .when I open it in visual studio environment as a solution/project , I don't know what should I do with .exe file to be runned. it's debug has .pdb error .
To:
Sent: Sunday, November 11, 2012 5:38 PM
Subject: Re: [cgal-discuss] runnig a demo in CGAL
AFAIK,if the demo in the demo folder is compiled, we'd get an app with GUI implemented by Qt whereas in the example there are just some cmd console app
sara ershadi <> wrote:
>Hi ,
>I am using CGAL totorial and My os is windows . How can I run trangulation3 demo ?
>PLz explain more.
>Thanks
>________________________________
> From: jhon chin <>
>To:
>Sent: Sunday, November 11, 2012 4:48 PM
>You can run it in the cmd window,or you can do some hacks in your code
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://sympa.inria.fr/sympa/info/cgal-discuss
- 回复: [cgal-discuss] 回复: [cgal-discuss] runnig a demo in CGAL, 乞丐开宝马, 11/12/2012
