cgal-discuss - Re: [cgal-discuss] cgal triangle-triangle intersection problem
  • To:
  • Subject: Re: [cgal-discuss] cgal triangle-triangle intersection problem
  • Date: Tue, 20 Nov 2012 11:17:51 +0100
Dongming Yan
writes:
> Dear CGAL developers,
> I encounter a problem when I compute the intersection of two triangles who
> share a common vertex. Here is the debug information:
> CGAL error: precondition violation!
> Expression : ! s1.is_degenerate() && ! s1.is_degenerate()
> File: cgal-4.0\include\CGAL\Intersections_3/intersection_3_1_impl.h
> Line: 262
> I attached two test examples which cause the problem. Any idea how to fix
> the problem? Thanks in advance.
Classical question first: Which kernel are you using? If it isn't exact,
please see the FAQ [1].
Footnotes:
[1] http://www.cgal.org/FAQ.html#kernels
