cgal-discuss - [cgal-discuss] Install macport
  • To:
  • Subject: [cgal-discuss] Install macport
  • Date: Fri, 30 Nov 2012 09:50:39 +0100 (CET)
I tried (on Mountain Lion)
$ port install cgal +demos+qt4+universal
it fails on libQGLViewer
then I tried
$ port install -f cgal +qt4+universal
then it failed on mpfr.
Is cgal macport install working for somebody ?
thanks
Olivier
[Users/odevil] > install cgal +qt4 +universal +demos
--->  Computing dependencies for cgal
--->  Dependencies to be installed: libQGLViewer metis mpfr
--->  Applying patches to libQGLViewer
Error: org.macports.patch for port libQGLViewer returned: command execution failed
Error: Failed to install libQGLViewer
Please see the log file for port libQGLViewer for details:
    /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_graphics_libQGLViewer/libQGLViewer/main.log
Error: The following dependencies were not installed: libQGLViewer metis mpfr
To report a bug, follow the instructions in the guide:
    http://guide.macports.org/#project.tickets
Error: Processing of port cgal failed
[Users/odevil] > install -f cgal  +qt4 +universal -f
--->  Dependencies to be installed: mpfr
--->  Fetching archive for mpfr
--->  Attempting to fetch mpfr-3.1.1-p2_0+universal.darwin_12.i386-x86_64.tbz2 from http://lil.fr.packages.macports.org/mpfr
--->  Attempting to fetch mpfr-3.1.1-p2_0+universal.darwin_12.i386-x86_64.tbz2 from http://mse.uk.packages.macports.org/sites/packages.macports.org/mpfr
--->  Attempting to fetch mpfr-3.1.1-p2_0+universal.darwin_12.i386-x86_64.tbz2 from http://packages.macports.org/mpfr
--->  Fetching distfiles for mpfr
--->  Attempting to fetch patch01 from http://lil.fr.distfiles.macports.org/mpfr/3.1.1
--->  Attempting to fetch patch02 from http://lil.fr.distfiles.macports.org/mpfr/3.1.1
--->  Attempting to fetch mpfr-3.1.1.tar.xz from http://lil.fr.distfiles.macports.org/mpfr/3.1.1
--->  Verifying checksum(s) for mpfr
--->  Extracting mpfr
--->  Applying patches to mpfr
--->  Configuring mpfr
--->  Building mpfr
--->  Staging mpfr into destroot
--->  Installing mpfr @3.1.1-p2_0+universal
--->  Activating mpfr @3.1.1-p2_0+universal
--->  Cleaning mpfr
--->  Fetching archive for cgal
Error: org.macports.archivefetch for port cgal returned: could not set effective gid to 501
Please see the log file for port cgal for details:
    /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/main.log
[Users/odevil] >
  • [cgal-discuss] Install macport, Olivier Devillers, 11/30/2012
