- To:
- Subject: Re: [cgal-discuss] Re: Meet A FATAL problem while compiling simple code
- Date: Fri, 07 Dec 2012 07:58:00 +0100
Crosscheck with this page:
http://www.cgal.org/windows_installation.html
and also check whether you choose debug/release compilation
with the boost library versions you have installed.
Sebastien.
On 12/07/2012 04:46 AM, Cynthia wrote:
I have already solved the problem, but there is another problem.
<http://cgal-discuss.949826.n4.nabble.com/file/n4656349/2.jpg>
It shows that "The computer has not found boost_thread-vc100-mt-gd-1_51.dll.
Please reload the library."
How to deal with it?
Thank you for your help.
Cynthia
Shanghai
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Meet-A-FATAL-problem-while-compiling-simple-code-tp4656348p4656349.html
- [cgal-discuss] Meet A FATAL problem while compiling simple code, Cynthia, 12/07/2012
- [cgal-discuss] Re: Meet A FATAL problem while compiling simple code, Cynthia, 12/07/2012
- Re: [cgal-discuss] Re: Meet A FATAL problem while compiling simple code, Sebastien Loriot (GeometryFactory), 12/07/2012
- [cgal-discuss] Re: Meet A FATAL problem while compiling simple code, Cynthia, 12/08/2012
- Re: [cgal-discuss] Re: Meet A FATAL problem while compiling simple code, Laurent Rineau (CGAL/GeometryFactory), 12/07/2012
