cgal-discuss - Re: [cgal-discuss] Building polyhedra.
  • To:
  • Subject: Re: [cgal-discuss] Building polyhedra.
  • Date: Mon, 10 Dec 2012 10:25:52 +0100
Le dimanche 09 décembre 2012 11:30:26 Noel Warren a écrit :
> I need to import a series of models from Sketchup into CGAL. Up to now
> I've been using the Sketchup API and a simple little script to triangulate
> faces which I then use to create an OFF file and build my CGAL Polyhedron.
> The problem is the Sketchup API uses floats and ocasionally creates
> degenerate OFF files. (This usually happens when I have two rectangular
> holes on a face that are closely lined up)
> The Sketchup model uses a structure very similar to that of CGAL with
> half_facets, half_edges, loops, etc. My question is, could I construct a
> Polyhedron from this type of data structure directly? If so how would I go
> about doing so.
You should the polyhedron incremental builder. That is an API to construct an
halfedges datastructure from scratch, using points and indices. See the
documentation, with a (too simple) example:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_incremental_builder_3.html
Laurent Rineau, PhD
