cgal-discuss - [cgal-discuss] Re: There are many errors in threetuple.h
  • To:
  • Subject: [cgal-discuss] Re: There are many errors in threetuple.h
  • Date: Mon, 10 Dec 2012 20:56:02 -0800 (PST)
I have found the right codes of threetuple.h through the internet, but there
are errors in some other files such as function_objects_3.h.
The original code:
// Copyright (c) 2006 Utrecht University (The Netherlands).
// All rights reserved.
// This file is a part of the Conformal Geometric Algebra Packge for CGAL;
// you may redistribute it under the terms of the Q Public License version
1.0.
// See the file LICENSE.QPL distributed with this package.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// Author(s) : Chaim Zonnenberg, Remco Veltkamp
#ifndef CGAL_GA_FUNCTION_OBJECTS_3_H
#define CGAL_GA_FUNCTION_OBJECTS_3_H
#include<CGAL/config.h>
#include <iostream>
#include <vector>
#include <CGAL/enum.h>
// Cartesian kernel only used for validation
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
#include <CGAL/Predicates/kernel_ftC3.h>
CGAL_BEGIN_NAMESPACE
// The following method is used for debugging
// It compares two 3d-points.
template <class FT>
static bool equalPointCoordinates(FT x1, FT x2, FT y1, FT y2, FT z1, FT z2)
double threshold = GA_Precision;
if (x1-x2>threshold) return false;
if (x2-x1>threshold) return false;
if (y1-y2>threshold) return false;
if (y2-y1>threshold) return false;
if (z1-z2>threshold) return false;
if (z2-z1>threshold) return false;
return true;
// Function object: Coplanar_orientation_3
// Call: ()(const Point_3& p, const Point_3& q, const Point_3& r)
// If p,q,r are collinear, then COLLINEAR is returned. If
// not, then p,q,r define a plane P. The return value in
// this case is either POSITIVE or NEGATIVE, but we don抰
// specify it explicitely. However, we guarantee that all calls
// to this predicate over 3 points in P will return a coherent
// orientation if considered a 2D orientation in P.
template <typename K>
class Coplanar_orientation_3
typedef typename K::Point_3 Point_3;
typedef typename K::FT FT;
typedef typename K::GA_Type GA_Type;
private:
The plane $P$ has the formula $P=p\wedge q \wedge r \wedge
\mathbf{e}_{\infty}$.
The plane with opposite orientation is $-P$. The dual of the plane
$P$ has
the form:
$\widetilde{P}=\mathbf{n}+d \mathbf{e}_{\infty}$, where $\mathbf{n}$
is the
3D-tangent
vector to the plane with generic formula $\mathbf{n}=a\mathbf{e}_1+b
\mathbf{e}_2+c
\mathbf{e}_3$, and where $d$ is the distance to from the plane to the
origin point
$\mathbf{e}_0$.\\ The direction of the normal vector (positive or
negative
also
determines its orientation. So a consistent orientation
(\ccc{POSITIVE} or
\ccc{NEGATIVE})
can be given by looking at the sign of one of the normal vector
co\"{e}fficients
($a$, $b$ or $c$). When such a co\"{e}fficient is zero, we should
look at
another
co\"{e}fficient. We do this in the order $c$, $b$, $a$, because in
that way
we get
the same results as the CartesianKernel-version of this function. When
\ccc{p,q,r}
are collinear, then $P=p\wedge q\wedge r\wedge \mathbf{e}_\infty$
returns
zero.
Orientation calculationGA(const Point_3& p, const Point_3& q, const
Point_3& r) const
GA_Type pp = p.normalize();
GA_Type qq = q.normalize();
GA_Type rr = r.normalize();
GA_Type plane = (pp^qq)^(rr^e_ni);
FT c = hip(plane.dual(), e_e3).scalar();
if (c<GA_Precision) return NEGATIVE;
if (c>GA_Precision) return POSITIVE;
FT b = hip(plane, e_e2).scalar();
if (b<GA_Precision) return NEGATIVE;
if (b>GA_Precision) return POSITIVE;
FT a = hip(plane, e_e1).scalar();
if (a<GA_Precision) return NEGATIVE;
if (a>GA_Precision) return POSITIVE;
return COLLINEAR;
public:
Orientation operator()(const Point_3& p, const Point_3& q, const
Point_3&
r) const
Orientation result = calculationGA(p,q,r);
#ifdef GA_VALIDATION
Orientation result2 = coplanar_orientationC3(p.x(), p.y(),
p.z(),
q.x(), q.y(), q.z(),
r.x(), r.y(), r.z());
if (result!=result2)
// Output the error as exact as possible
p.print("\n p: ");
q.print("\n q: ");
r.print("\n r: ");
std::cerr << "\n GA_Result: " << result;
std::cerr << "\n C3_Result: " << result2;
// Terminate the program
CGAL_precondition(false);
#endif
return result;
// Function object: orientation_3
// Call: ()(const Point_3& p, const Point_3& q, const Point_3& r,
const Point_3& s)
// returns \ccStyle{POSITIVE}, if $s$ lies on the positive side of the
oriented
// plane $h$ defined by $p$, $q$, and $r$, returns \ccStyle{NEGATIVE} if $s$
// lies on the negative side of $h$, and returns \ccStyle{COPLANAR} if $s$
lies
// on $h$.
class Orientation_3
public:
typedef Orientation result_type;
The GA-formula $S = p\wedge q\wedge r\wedge s$ defines an oriented
sphere.
This orientation
can be determined by looking at the sign of the $\mathbf{e}_0$
co\"efficient. This
co\"efficient $c$ can easily be calculated by taking the inner
product of S
with
$\mathbf{e}_\infty$: $c=-S\cdot\mathbf{e}_\infty$ (because
$\mathbf{e}_0\cdot
\mathbf{e}_\infty=-1$, while $\mathbf{e}_i\cdot\mathbf{e}_\infty=0$
where
$1\leq i
\leq 3$ and $\mathbf{e}_\infty\cdot\mathbf{e}_\infty=0$).
Orientation calculationGA( const Point_3& p, const Point_3& q,
const Point_3& r, const Point_3& s) const
// Points should be normalized (i.e. have positive
orientation)
GA_Type ss = s.normalize();
GA_Type sphere = (pp^qq)^(rr^ss);
FT value = hip(sphere.dual(), e_ni).scalar();
if (value>GA_Precision) return RIGHT_TURN;
if (value<GA_Precision) return LEFT_TURN;
return ZERO;
Orientation operator()( const Point_3&amp; p, const Point_3&amp; q,
const Point_3&amp; r, const Point_3&amp; s) const
Orientation result = calculationGA(p,q,r,s);
Orientation result2 = orientationC3(p.x(), p.y(), p.z(),
r.x(), r.y(), r.z(),
s.x(), s.y(), s.z());
p.print(&quot;\n p: &quot;);
q.print(&quot;\n q: &quot;);
r.print(&quot;\n r: &quot;);
s.print(&quot;\n s: &quot;);
std::cerr &lt;&lt; &quot;\n GA_Result: &quot;
&lt;&lt; result;
std::cerr &lt;&lt; &quot;\n C3_Result: &quot;
&lt;&lt; result2;
#endif
return result;
// Function object: Construct_circumcenter_3
// Call: ()(const Point_3&amp; p, const Point_3&amp; q, const
// compute the center of the circle passing through the points $p$, $q$ and
$r$.
// \ccPrecond $p$, $q$ and $r$ are not collinear.
template &lt;typename K>
class Construct_circumcenter_3
First the circle $C$ through the points $p$, $q$ and $r$ is
constructed.
After that
the centre of this circle is calculated. The circle has GA-formula:
$C=p\wedge
q\wedge r$. The middlepoint of the circle is $m=\frac{(C
\mathbf{e}_\infty
C)}
{2 (\mathbf{e}_\infty\cdot C)^2}$
Point_3 calculationGA(const Point_3& p, const Point_3& q, const
Point_3& r)
const
GA_Type s = p^(q^r); // s is the GA-circle through the
points p, q and r
// Precondition: p, q and r should not be on one line.
// A circle is a round in CGA. A property of a round is that
its square
(s*s) is unequal to zero.
FT test = (s*s).scalar();
CGAL_kernel_assertion((-GA_Precision<test) ||
(test>GA_Precision)); //test
wheter it is zero or not
// calculate result
GA_Type result = (s * e_ni * s) / (hip(e_ni,s) *
hip(e_ni,s))/2;
return Point_3(Point_3(result).normalize());
public:
Point_3 operator()(const Point_3& p, const Point_3& q, const Point_3&
r)
const
Point_3 result = calculationGA(p,q,r);
FT x, y, z;
circumcenterC3(p.x(), p.y(), p.z(),
x, y, z);
if (!equalPointCoordinates(x,result.x(), y, result.y(), z,
result.z()))
p.print("\n p: ");
q.print("\n q: ");
r.print("\n r: ");
result.print("\n GA_Result: ");
std::cerr << "\n C3_Result: " << x << " " << y << " "
<< z << " ";
#endif
return result;
// Function object: Compare_distance_3
// Call: ()(const Point_3&p, const Point_3&q, const Point_3&r);
// compares the distances of points \ccc{q} and \ccc{r} to point \ccc{p}
class Compare_distance_3
In CGA the distance between two normalized points $p$ and $q$ can be
calculated
with the following formula $d(p,q)=\sqrt{-2(p\cdot q)}$. This
function only
returns which of the two distances is the smallest; therefore taking
the
square
roots is not necessary, because that does not affect the result of the
function.
Comparison_result calculationGA(const Point_3& p, const Point_3& q,
const
Point_3& r) const
FT minus2sqrdistPQ = hip(p.normalize(),
q.normalize()).scalar();
FT minus2sqrdistPR = hip(p.normalize(),
r.normalize()).scalar();
if (minus2sqrdistPQ>minus2sqrdistPR) return SMALLER;
if (minus2sqrdistPQ<minus2sqrdistPR) return LARGER;
return EQUAL;
public:
Comparison_result operator()(const Point_3&amp; p, const Point_3&amp;
q,
const Point_3&amp; r) const
Comparison_result result = calculationGA(p,q,r);
Comparison_result result2 = cmp_dist_to_pointC3(p.x(), p.y(),
p.z(),
&lt;&lt; result;
&lt;&lt; result2;
#endif
return result;
// Function object: Compare_xyz_3
// Call: ()( const Point_3&amp; p, const Point_3&amp; q);
Compares the Cartesian coordinates of points \ccStyle{p} and
\ccStyle{q} lexicographically in $xy$ order: first
$x$-coordinates are compared, if they are equal, $y$-coordinates
are compared. If they are equal, $z$-coordinates are compared.
class Compare_xyz_3
public:
This function uses cartesian co\"ordinates to perform this comparison
(see
function requirements above). In the GA-kernel this method has a more
generic implementation. To calculate the cartesian co\"ordinates a
special
C3GA-kernel function \ccStyle{default_base_element(index)} is used.
This
function gives 3 orthogonal unit base vectors. By default it returns
the
cartesian unit base vectors. Other orthogonal vectors can be used by
adapting this function.
Comparison_result operator()( const Point_3& p, const Point_3& q)
const
FT p1 = hip(pp, K::default_base_element(1)).scalar();
FT q1 = hip(qq, K::default_base_element(1)).scalar();
if (p1<q1) return SMALLER;
if (p1>q1) return LARGER;
FT p2 = hip(pp, K::default_base_element(2)).scalar();
FT q2 = hip(qq, K::default_base_element(2)).scalar();
if (p2<q2) return SMALLER;
if (p2>q2) return LARGER;
FT p3 = hip(pp, K::default_base_element(3)).scalar();
FT q3 = hip(qq, K::default_base_element(3)).scalar();
if (p3<q3) return SMALLER;
if (p3>q3) return LARGER;
return EQUAL;
// Function object: Coplanar_side_of_bounded_circle_3
// Call: ()( const Point_3& p, const Point_3& q,
// const Point_3& r, const Point_3& t);
returns the bounded side of the circle defined
by \ccc{p}, \ccc{q}, and \ccc{r} on which \ccc{t} lies.
\ccPrecond \ccc{p}, \ccc{q}, \ccc{r}, and \ccc{t} are coplanar and
\ccc{p}, \ccc{q}, and \ccc{r} are not collinear.
class Coplanar_side_of_bounded_circle_3
First this function calculates the circumcenter point $m$ of the
given
point. Then it calculates the distance from $m$ to $p$ with the
distance
from $m$ to $t$.
Bounded_side calculationGA( const Point_3& p, const Point_3& q,
const Point_3& r, const Point_3& t) const
// Precondition check: p, q, r and t should be in the same
plane
FT test = (hip((p^q)^(r^t),(p^q)^(r^t) )).scalar();
CGAL_kernel_assertion(-GA_Precision<= test && test <=
GA_Precision);
// Second precondition is checked by construct_circumcenter_3
Point_3 m = K().construct_circumcenter_3_object()(p,q,r); //
point in the
middle of circle through p, q, r
Comparison_result res = K().compare_distance_3_object()(m, p,
t);
if (res==SMALLER) return ON_UNBOUNDED_SIDE;
if (res==LARGER) return ON_BOUNDED_SIDE;
return ON_BOUNDARY;
public:
Bounded_side operator()( const Point_3& p, const Point_3& q,
Bounded_side result = calculationGA(p,q,r,t);
Bounded_side result2 =
coplanar_side_of_bounded_circleC3(p.x(), p.y(),
p.z(),
t.x(), t.y(), t.z());
p.print("\n p: ");
q.print("\n q: ");
r.print("\n r: ");
t.print("\n t: ");
#endif
return result;
// Function object: Side_of_oriented_sphere_3
// Call: ()( const Point_3& p, const Point_3& q, const Point_3&
r,
// const Point_3& s, const
Point_3& test)
returns the relative position of point \ccStyle{t}
to the oriented sphere defined by $p$, $q$, $r$ and $s$.
The order of the points $p$, $q$, $r$, and $s$ is important,
since it determines the orientation of the implicitly
constructed sphere. If the points $p$, $q$, $r$ and $s$
are positive oriented, positive side is the bounded interior
of the sphere.
class Side_of_oriented_sphere_3
typedef Oriented_side result_type;
typedef Arity_tag< 5 > Arity;
/* First the sphere is calculated: $B=p\wedge q\wedge r\wedge
s$. (a sphere
always has an orientation) Then the sign of the orientation can be
determined by looking at the sign of the scalar $t\cdot\widetilde{B}
Oriented_side
calculationGA( const Point_3& p, const Point_3& q, const
Point_3& r,
const Point_3& s, const Point_3& test) const
// Precondition check: p, q, r and t should not be in the
same plane
FT testScalar = (hip((p^q)^(r^s),(p^q)^(r^s) )).scalar();
CGAL_kernel_assertion(testScalar<-GA_Precision || testScalar>
GA_Precision);
GA_Type testt = test.normalize();
GA_Type dualSphere = ((pp^qq)^(rr^ss)).dual();
FT scalar = hip(testt,dualSphere).scalar();
if (scalar<-GA_Precision) return ON_NEGATIVE_SIDE;
if (scalar>GA_Precision) return ON_POSITIVE_SIDE;
return ON_ORIENTED_BOUNDARY;
public:
Oriented_side
operator()( const Point_3& p, const Point_3& q, const
Point_3& r,
Oriented_side result =calculationGA(p,q,r,s,test);
Oriented_side result2 = side_of_oriented_sphereC3(p.x(),
p.y(), p.z(),
s.x(), s.y(), s.z(),
test.x(), test.y(), test.z());
p.print("\n p: ");
q.print("\n q: ");
r.print("\n r: ");
s.print("\n s: ");
test.print("\n test: ");
#endif
return result;
// Function object: Construct_perpendicular_line_3
// Call: ()( const Plane_3& pl, const Point_3& p);
// returns the line that is perpendicular to \ccc{pl} and that
// passes through point \ccStyle{p}. The line is oriented from
// the negative to the positive side of \ccc{pl}
class Construct_perpendicular_line_3
typedef typename K::Line_3 Line_3;
typedef typename K::Plane_3 Plane_3;
public:
This is done by calculating the normal vector to the plane \ccc{pl}:
\ccc{f}
(in GA-free-vector form).
$f=\widetilde{\mbox{pl}}\wedge\mathbf{e}_\infty$.
The line is calculated by taking the join (i.e. outer product) of $f$
and
$p$.
Line_3 operator()( const Plane_3& pl, const Point_3& p) const
return Line_3( (pl.base.dual() ^ e_ni) ^ pp);
class Construct_plane_3
typedef typename K::RT RT;
typedef typename K::Vector_3 Vector_3;
typedef typename K::Direction_3 Direction_3;
typedef typename K::Ray_3 Ray_3;
typedef typename K::Segment_3 Segment_3;
public:
typedef Plane_3 result_type;
typedef Arity_tag< 2 > Arity;
Plane_3
operator()() const
{ return Plane_3(); }
creates a plane passing through the points \ccStyle{p},
\ccStyle{q} and \ccStyle{r}. The plane is oriented such that
\ccStyle{p},
\ccStyle{q} and \ccStyle{r} are oriented in a positive sense
(that is counterclockwise) when seen from the positive side of the
plane.
Notice that is degenerate if the points are collinear.
Plane_3 operator()(const Point_3& p, const Point_3& q, const
Point_3& r)
const
return Plane_3(p^q^r^e_ni);
introduces a plane that passes through point \ccStyle{p} and
that has as an orthogonal direction equal to \ccStyle{d}.
Plane_3 operator()(const Point_3& p, const Direction_3& d) const
{ return Plane_3(p, d); }
that is orthogonal to \ccStyle{v}.
Plane_3
operator()(const Point_3& p, const Vector_3& v) const
{ return Plane_3(p, v); }
introduces a plane that passes through the line \ccStyle{l} and the
point \ccStyle{p}.
Plane_3
operator()(const Line_3& l, const Point_3& p) const
{ return Plane_3(l, p); }
introduces a plane that is defined through the ray \ccStyle{r}
and the point \ccStyle{p}.
Plane_3
operator()(const Ray_3& r, const Point_3& p) const
{ return Plane_3(r, p); }
introduces a plane that is defined through the segment \ccStyle{s}
Plane_3
operator()(const Segment_3& s, const Point_3& p) const
{ return Plane_3(s, p); }
class Construct_ray_3
public:
introduces a ray with source $p$ and with the direction given by $v$.
Ray_3
{ return Ray_3(p, v); }
the same direction as $l$.
Ray_3
operator()(const Point_3& p, const Line_3& l) const
{ return Ray_3(p, l); }
/* template <typename K>
class Construct_object_3
typedef typename K::Object_3 Object_3;
public:
typedef Object_3 result_type;
typedef Arity_tag< 1 > Arity;
template <class Cls>Object_3 operator()( const Cls& c) const
//TODO
//return make_object(c);
class Construct_segment_3
public:
introduces an uninitialized variable
Segment_3
operator()() const
{ return Segment_3(); }
introduces a segment with source $p$ and target $q$. It is directed
from
the source towards the target.
Segment_3
operator()( const Point_3& p, const Point_3& q) const
return Segment_3(p,q);
class Construct_triangle_3
typedef typename K::Triangle_3 Triangle_3;
public:
// introduces an uninitialized variable
Triangle_3
operator()() const
return Triangle_3();
// introduces a triangle with vertices $p$, $q$ and $r$.
Triangle_3
Point_3& r) const
return Triangle_3(p, q, r);
class Construct_tetrahedron_3
typedef typename K::Tetrahedron_3 Tetrahedron_3;
public:
// introduces a tetrahedron with vertices $p$, $q$, $r$ and $s$
Tetrahedron_3
{ return Tetrahedron_3(p, q, r, s); }
CGAL_END_NAMESPACE
#endif //CGAL_GA_FUNCTION_OBJECTS_3_H
Cynthia
Shanghai
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/There-are-many-errors-in-threetuple-h-tp4656364p4656373.html
