- To: mschneider <>
- Cc:
- Subject: Re: [cgal-discuss] CGAL 4.1: Straight skeleton infinite loop workaround
- Date: Fri, 14 Dec 2012 11:47:25 +0100
mschneider
writes:
> Hi,
> there is an infinite loop in
> [include/CGAL/Straight_skeleton_2/Straight_skeleton_builder_2_impl.h]
> Template Function:
> template<class Gt, class Ss, class V>
> void Straight_skeleton_builder_2<Gt,Ss,V>::MergeCoincidentNodes()
> We had to add a infinite loop checker. The code is pretty simple and only a
> workaround for the problem to make the application robost for special user
> data. There is now a handleList which adds the current node's handle. If the
> node's handle is known we'll throw a exception to get outa loop.
> This is the diff file:
> 1696,1698d1695
> < std::list<int> handleListID;
> < handleListID.push_back( h->id() );
> 1718,1723d1714
> < // check for infinite loop
> < if (std::find( handleListID.begin(), handleListID.end(), h->id() )
> < handleListID.end())
> < throw std::runtime_error( "detected infinite loop." );
Hi,
thanks for the patch. Could you provide a data-set and some code to
reproduce that problem? That way we can look for a fully correct fix.
Cheers,
Philipp
- [cgal-discuss] CGAL 4.1: Straight skeleton infinite loop workaround, mschneider, 12/14/2012
- Re: [cgal-discuss] CGAL 4.1: Straight skeleton infinite loop workaround, Philipp Moeller, 12/14/2012
