- To:
- Subject: [cgal-discuss] Missing .dll Error
- Date: Tue, 18 Dec 2012 14:06:04 +0000
Hi,
I've successfully installed CGAL 3.x on a Windows XP 32bit box with Visual Studio 2008 and managed to get a convex hull routine working nicely in Autodesk Softimage, but since upgrading to a Windows 7 64bit environment with Visual Studio 2010 Express (with Windows 7.1 SDK for 64bit support) I've been having a few problems.
I've installed CGAL 4.1 and Boost 1.51. CGAL looks as though it is built properly. But, when I compile the Convex_hull_2 examples I get a successful log but an error from the .exe:
"The program can't start because CGAL-vc100-mt-4.1.dll is missing from your computer."
As far as I can tell the build log is fine (see below).
I'm sure I'm doing something completely stupid but I can't figure out why this is happening. The relevant .dll seems to be in the CGAL folder. I'm not a full-time C++ programmer (I'm a 3D CG Artist) so I'm at a loss when it comes to working out what the problem could be. I assumed if there were no link errors and I had a successful compile then there shouldn't be a problem....
If anyone has any ideas they would be gratefully received.
Julian Johnson
Glassworks London
Log:
1>------ Build started: Project: ZERO_CHECK, Configuration: Release x64 ------
1> Checking Build System
1> CMake does not need to re-run because C:/Program Files (x86)/CGAL-4.1/build_examples/Convex_hull_2/CMakeFiles/generate.stamp is up-to-date.
2>------ Build started: Project: ch_timing, Configuration: Release x64 ------
3>------ Build started: Project: ch_graham_anderson, Configuration: Release x64 ------
4>------ Build started: Project: ch_from_cin_to_cout, Configuration: Release x64 ------
5>------ Build started: Project: array_convex_hull_2, Configuration: Release x64 ------
6>------ Build started: Project: iostream_convex_hull_2, Configuration: Release x64 ------
7>------ Build started: Project: vector_convex_hull_2, Configuration: Release x64 ------
5> Building Custom Rule C:/Program Files (x86)/CGAL-4.1/examples/Convex_hull_2/CMakeLists.txt
7> Building Custom Rule C:/Program Files (x86)/CGAL-4.1/examples/Convex_hull_2/CMakeLists.txt
4> Building Custom Rule C:/Program Files (x86)/CGAL-4.1/examples/Convex_hull_2/CMakeLists.txt
2> Building Custom Rule C:/Program Files (x86)/CGAL-4.1/examples/Convex_hull_2/CMakeLists.txt
6> Building Custom Rule C:/Program Files (x86)/CGAL-4.1/examples/Convex_hull_2/CMakeLists.txt
3> Building Custom Rule C:/Program Files (x86)/CGAL-4.1/examples/Convex_hull_2/CMakeLists.txt
5> CMake does not need to re-run because C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\CMakeFiles\generate.stamp is up-to-date.
7> CMake does not need to re-run because C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\CMakeFiles\generate.stamp is up-to-date.
2> CMake does not need to re-run because C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\CMakeFiles\generate.stamp is up-to-date.
4> CMake does not need to re-run because C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\CMakeFiles\generate.stamp is up-to-date.
6> CMake does not need to re-run because C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\CMakeFiles\generate.stamp is up-to-date.
3> CMake does not need to re-run because C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\CMakeFiles\generate.stamp is up-to-date.
5> array_convex_hull_2.cpp
4> ch_from_cin_to_cout.cpp
3> ch_graham_anderson.cpp
7> vector_convex_hull_2.cpp
6> iostream_convex_hull_2.cpp
2> ch_timing.cpp
4> ch_from_cin_to_cout.vcxproj -> C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\Release\ch_from_cin_to_cout.exe
6> iostream_convex_hull_2.vcxproj -> C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\Release\iostream_convex_hull_2.exe
3> ch_graham_anderson.vcxproj -> C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\Release\ch_graham_anderson.exe
5> array_convex_hull_2.vcxproj -> C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\Release\array_convex_hull_2.exe
7> vector_convex_hull_2.vcxproj -> C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\Release\vector_convex_hull_2.exe
2> ch_timing.vcxproj -> C:\Program Files (x86)\CGAL-4.1\build_examples\Convex_hull_2\Release\ch_timing.exe
8>------ Skipped Build: Project: ALL_BUILD, Configuration: Release x64 ------
8>Project not selected to build for this solution configuration
========== Build: 7 succeeded, 0 failed, 0 up-to-date, 1 skipped ==========
- [cgal-discuss] Missing .dll Error, Julian, 12/18/2012
- Re: [cgal-discuss] Missing .dll Error, Julian, 12/18/2012
- Re: [cgal-discuss] Missing .dll Error, sara ershadi, 12/18/2012
