- To:
- Subject: [cgal-discuss] Installation of CGAL - Can't Find Boost Libraries
- Date: Fri, 28 Dec 2012 08:59:16 -0800 (PST)
Hi,
I know that I'm bothering you with a really common and boring issue, however - I get
this error during the Cmake
Configuring Step:
CMake Error at C:/Program Files (x86)/CMake
2.8/share/cmake-2.8/Modules/FindBoost.cmake:1192 (message):
Unable to find the requested Boost libraries.
Unable to find the Boost header files. Please set BOOST_ROOT to the root
directory containing Boost or BOOST_INCLUDEDIR to the directory containing
Boost's headers.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:85 (include)
CMakeLists.txt:590 (include)
I downloaded the Boost installer here: http://www.boostpro.com/download/. Then I
installed it on the D drive (the OS is on the C drive) because I haven't enough disk
space on C. Then I provided the
Boost directory in the Boost_DIR string in Cmake-GUI (see the red circle in the
attachment) and restarted the
Configure Step. But the directory gets cleaned every time so the Configuring is
incomplete.
What is wrong?
Thank you a lot
Best regards,
Davide Tonelli
View this message in context: Installation of CGAL - Can't Find Boost Libraries
- [cgal-discuss] Installation of CGAL - Can't Find Boost Libraries, d.tonelli, 12/28/2012
- Re: [cgal-discuss] Installation of CGAL - Can't Find Boost Libraries, sara ershadi, 12/28/2012
