cgal-discuss - Re: [cgal-discuss] Spherical Arrangement_on_surface_2
  • To:
  • Subject: Re: [cgal-discuss] Spherical Arrangement_on_surface_2
  • Date: Sat, 12 Jan 2013 16:54:43 -0500
  • Priority: normal
Can you clarify what you mean by special cases? Are you referring to
degenerate cases of the arrangement itself, or to functions such as
insert_in_face_interior and insert_from_left_vertex, meaning that using
CGAL::insert is safe and correct to use?
----- Original Message -----
Date: Sunday, January 6, 2013 2:39 am
> Arrangement on the sphere is not formally supported. The code that
> handlesthe general case has been generalized, but code that handles
> special cases
> is still missing.
> In general the same guidelines that apply to arrangement in the
> plane also
> applies to arrangement on the sphere.
> You can extend the curve either with *
> CGAL::Arr_curve_data_traits_2<Tr,XData,Mrg,CData,Cnv><http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Class_Arr_curve_data_traits_2.html#Cross_link_anchor_1262>or
> with
> *CGAL::Arr_consolidated_curve_data_traits_2<Traits,Data><http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Class_Arr_consolidated_curve_data_traits_2.html#Cross_link_anchor_1263>
> *. You can extend an edge (more precisely, a halfedge)
> using*CGAL::Arr_extended_dcel<Traits,VData,HData,FData,V,H,F><http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2_ref/Class_Arr_extended_dcel.html#Cross_link_anchor_1216>
> *or the general technique described in Section
> Extending the
> Dcel<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Arrangement_on_surface_2/Chapter_main.html#Section_32.8>.There
> are examples to do either.
> On Sat, Jan 5, 2013 at 11:16 PM, Evan S Behar
> wrote:
> > Hello,
> > I'm wondering if there's a straightforward way to modify the
> arrangement> structure on a sphere such that the vertices/edges in
> the arrangement have
> > additional information from the curves that are used to create them.
> > Essentially I am looking to add annotations to the arrangement.
> > I would like to replace Curve_2 with a structure that has an
> annotation> (e.g., a label) and have vertices/edges in the
> arrangement keep a list of
> > the labels of the curves that pass through them, but I don't know
> if there
> > is already a clear way to do this.
> > Thanks,
> > Evan
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://sympa.inria.fr/sympa/info/cgal-discuss
> ____ _ ____ _
> /_____/_) o /__________ __ //
> (____ ( ( ( (_/ (_/-(-'_(/
> _/
