- To:
- Subject: Re: [cgal-discuss] Re: Number of tetrahedra
- Date: Thu, 17 Jan 2013 22:43:07 +0200
Le 17/01/13 17:39, Zohar Levi a écrit :
I posted a reply through the site, but it got mangled. So I send it again by email:I cited the ratio 7-8 from what I remember, and if I remember well this ratio was referring to triangulations of set of points, that is triangulation that fill the convex hull of the vertices. The difference with your results might come from the fact that you have no internal points and do not count tetrahedra outside of the object
-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Number of tetrahedra, Zohar, 01/17/2013
- Re: [cgal-discuss] Number of tetrahedra, Mariette Yvinec, 01/17/2013
- [cgal-discuss] Re: Number of tetrahedra, Zohar, 01/17/2013
- Re: [cgal-discuss] Re: Number of tetrahedra, Zohar Levi, 01/17/2013
- Re: [cgal-discuss] Re: Number of tetrahedra, Olivier Devillers, 01/17/2013
- Re: [cgal-discuss] Re: Number of tetrahedra, Mariette Yvinec, 01/17/2013
- [cgal-discuss] Re: Number of tetrahedra, Zohar, 01/18/2013
