cgal-discuss - Re: [cgal-discuss] Re: Line sweep example gives invalid results
  • To:
  • Subject: Re: [cgal-discuss] Re: Line sweep example gives invalid results
  • Date: Sat, 19 Jan 2013 21:18:49 +1000
I'm guessing it just the way the results are formatted when they are printed.
Now that I look more closely at the results
-21/-7 => 3 so that (-21/-7, -21/-7) really means (3, 3) and so on ....
Cheers,
Kieran
On Sat, Jan 19, 2013 at 9:14 PM, kierans <> wrote:
Hi Efi,
I wasn't aware of the parameter that indicates whether to report endpoints or not - that may well explain why the number of intersections is 3 instead of 5. My bad :)
What about the values reported for the intersections themselves ? The values are negative and dont seem to match what I got drawing the example by hand. Is there some strange coordinate system in use ?? I've probably got the wrong end of the stick but I reckon the answers should be:
* (3,3)
* (3,5)
* (5,5)
* (8,8)
* (8,5)
not
* (-21/-7, -21/-7)
* (-3/-1, -5/-1)
* (-35/-7, -35/-7)
Apologies in advance for my ignorance :)
Cheers,
Kieran
On Sat, Jan 19, 2013 at 9:03 PM, Efi Fogel [via cgal-discuss] <[hidden email]> wrote:
I don't see the problem.
The forth argument of compute_intersection_points() indicates whether to report endpoints. By default the value of this argument is false. Thus, only 3 intersections are reported.
On Sat, Jan 19, 2013 at 12:36 PM, kierans <[hidden email]> wrote:
Hi there,
I built CGAL-4.1 and managed to get the
Arrangement_on_surface2_example/sweep_line to build and run. Unfortunately
for me it gives total bogus results :( It gets the number of intersections
and their values wrong.
From my reading of the example it should find 5 intersections at the
following locations:
* (3,3)
* (3,5)
* (5,5)
* (8,8)
* (8,5)
When I debug the example I get the following output:
Found 3 intersection points:
-21/-7 -21/-7
-3/-1 -5/-1
-35/-7 -35/-7
I am running on windows 7,  Microsoft Visual Studio VC++ 2010 Express
(32-bit), Boost 1.51 (32-bit) and CGAL-4.1. Any ideas on what's going on ?
Cheers,
Kieran
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Line-sweep-example-gives-invalid-results-tp4656497.html
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/Line-sweep-example-gives-invalid-results-tp4656497p4656498.html
To unsubscribe from Line sweep example gives invalid results, click here.
NAML
View this message in context: Re: Line sweep example gives invalid results
