- To:
- Subject: Re: [cgal-discuss] install issues
- Date: Mon, 21 Jan 2013 07:07:36 +0100
On 01/20/2013 02:22 PM, christophe malvasio wrote:
thanks sebastien
So I don't understand why you are saying that cmake turn them off.
i saw them off in cmake cache
Eigen3
ok what about blas/lapack of it ?
no use for better CGAL ?
The same goes for blas/lapack, even if we stopped
advertise to using them since we now recommend using Eigen.
CGAL is about geometric algorithms, only the display could take
This was intended to fix a bug in GCC 4.2
said like that i'm afraid to be boring at best
also are you all in freebsd to use this regex ?
What do you mean?
4.2 is top gcc for many freebsd users :(
cmake output give :-- USING OPENGL_VERSION = '2.1'
mesa give 3.0 no use ?
What is the problem here? The opengl dectected is not the one
you would like to use?
this question was again to know if there is possible improvements but
with opengl 3.x.x
advantage of it. We do not use anything specific to these versions.
Sebastien.
Sebastien.
forgive me ^ please
thanks
again and sorry for annoy
- [cgal-discuss] install issues, christophe malvasio, 01/20/2013
- Re: [cgal-discuss] install issues, Sebastien Loriot (GeometryFactory), 01/20/2013
- Re: [cgal-discuss] install issues, christophe malvasio, 01/20/2013
- Re: [cgal-discuss] install issues, Sebastien Loriot (GeometryFactory), 01/21/2013
- Re: [cgal-discuss] install issues, christophe malvasio, 01/21/2013
