cgal-discuss - Re: [cgal-discuss] Buffer with 3d polygon
  • To:
  • Subject: Re: [cgal-discuss] Buffer with 3d polygon
  • Date: Tue, 22 Jan 2013 16:26:10 +0100
If your polygon is planar but in 3D, you can compute a 2D polygon in the supporting plane and use this package [1].
If your polygon is almost planar, you can use this package [2] to compute the best plane approximation.
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Minkowski_sum_2/Chapter_main.html
[2] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Principal_component_analysis/Chapter_main.html
On 01/22/2013 03:16 PM, mastair wrote:
I want to buffer a polygon in 3d space. Apparently Minkowski sum only takes
NEF polyhedra as input?
How would I create a buffer around a polygon in 3d space, as such creating a
NEF polyhedron or general polyhedron?
Thank you for your help.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Buffer-with-3d-polygon-tp4656520.html
