- To:
- Subject: Re: [cgal-discuss] Unsure how distance_bound in CGAL mesh works
- Date: Tue, 22 Jan 2013 18:16:29 +0200
Dear Paul as you noticed, the radious-bound controls the size of surface Delaunay balls, hence the size of surface facets. The distance bound controls the distance between the circumcenter of a mesh facet and the center of a surface Delaunay ball of this facet. This distance is a measure of the accuracy of the approximation of the surface by the mesh. Increasing this bounds, means relaxing the required accuracy and therefore decreasing the mesh density. Decreasing it on the contrary tend to increase the mesh density because a better accuracy is required. However, setting the bound to zero, means that the mesh has no prescribed accuracy goal and the distance criteria is not be taken account. I hope this helps, Mariette Le 21/01/13 08:36, paulm a écrit :
To whom it may concern, I've been using iso2mesh for a while now to create volume meshes for Abaqus. I'm using CGAL mesh to generate the tetrahedral meshes and controlling the density with the opt.radbound (radius_bound) and opt.distbound (distance_bound) parameters. I understand that radius_bound is radii of surface Delaunay balls (i.e the size of each tertrahedral element). According to your documentation, distance_bound is an upper bound for the distance between the circumcenter of a mesh facet and the center of a surface Delaunay ball of this facet. My testing shows that for a fixed radius_bound, increasing the distance_bound value reduces the number of elements generated to a point. Also setting the distance_bound = 0 reduces the number of elements as well. I understand that a tetra element has four faces and the distance_bound is the limit the circumcentres that these four faces can be from the centre of the Delaunay ball that surrounds it. Therefore increasing this allowable distance_bound will increase the size of the element size. I have three questions. 1) If increasing this allowable distance_bound will increase the size of the element size, why doesn't it do it indefinitely. Is it being limited by a fixed radius_bound? 2) Besides element size, can altering distance_bound change other element attributes (i.e. variations in element aspect ratio, skewedness etc)? 3) Do you know of any worthwhile papers that discuss distance_bound in detail? Thanks for your help and kind regards, Paul -- View this message in context: http://cgal-discuss.949826.n4.nabble.com/Unsure-how-distance-bound-in-CGAL-mesh-works-tp4656509.html Sent from the cgal-discuss mailing list archive at Nabble.com. -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Unsure how distance_bound in CGAL mesh works, paulm, 01/21/2013
- Re: [cgal-discuss] Unsure how distance_bound in CGAL mesh works, Mariette Yvinec, 01/22/2013
