cgal-discuss - Re: [cgal-discuss] Re: 2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib'
  • To: "" <>
  • Subject: Re: [cgal-discuss] Re: 2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib'
  • Date: Tue, 22 Jan 2013 12:52:38 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=IhAd9m1r2YbPGhHRvOoCOpFfeyVW/T674UUSneSNVVL6QDegnyHq2aWZI9bKwTO4NDxYsA1rpSOMt3nLUG8PBZkMxTLFrAJ8V20m3mQtdNGkYa2iQ/PxF4FS+4we80gf2jHnvAPQGWwnS/ftq79B/qmIBYzxyXkVmE9VtunPoBs=;
Hi ,
Thanks alot for reply.
But I have the problem still . I have configure the CGAL with cmake then generate and then open the CGAL.sln that is created in build folder and then I am tring to debug the project contin in solution explorer folder. but when I try this error will appeared about not founding   .
I try once to set the install as start uo project but it reaches the same error .
what should I do ?
Is it possible to say what I should do ?
thanks
To:
Sent: Monday, January 21, 2013 1:48 AM
Subject: [cgal-discuss] Re: 2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib'
i had a similar problem, this one i think is nothing to do with boost.
its the cgal library file which the compiler is searching.
and if i am not wrong, then possibly, you are not building the project in
debug mode also. thts why you are getting this error.
after you install using cmake, then you need to build the project. in debug
mode
(this is where you get the files with -gd- in the names.) and in release
mode.
and link the folder in your configuration flags (for e.g. the .pro file in
QT)
most important fact to consider. compile all the libraries either for 32 bit
or 64 bit
sometime it also creates a problem. i lost a weeks time because of such a
small error.
good luck.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/2-LINK-fatal-error-LNK1104-cannot-open-file-CGAL-vc100-mt-gd-4-0-lib-tp4656510p4656512.html
