- To:
- Subject: Re: [cgal-discuss] Another boring linking question
- Date: Wed, 23 Jan 2013 07:39:23 +0100
Could you cross check with the following tutorial?
http://www.cgal.org/windows_installation.html
Sebastien.
On 01/23/2013 04:01 AM, Rhys D wrote:
Hi,
I have just started with CGAL and can't get any of the demos to compile.
I am using Boost 1.51
Here is the verbose VC++ error
You can see that it is searching in what seems to me to be the correct
lib file but is still failing.
My environment:
Windows 7 x64
Visual Studio 2010
Boost 1.51 - 64 downloaded from here: http://www.boostpro.com/download/
CGAL-4.1
I have reinstalled everything from scratch but still keep coming up
against the same error.
I am building Release x64. at all steps I have chosen
Any ideas?
Rhys.
1> Searching
C:\dev\CGAL-4.1-static\CGAL-4.1\build\lib\Release\CGAL-vc100-mt-4.1.lib:
1> Searching C:\dev\boost_1_51\lib\libboost_thread-vc100-mt-1_51.lib:
1> Searching C:\dev\boost_1_51\lib\libboost_system-vc100-mt-1_51.lib:
1> Searching
C:\dev\boost_1_51\lib\libboost_date_time-vc100-mt-1_51.lib:
1> Searching C:\dev\boost_1_51\lib\libboost_chrono-vc100-mt-1_51.lib:
1> Searching C:\Program Files (x86)\Microsoft Visual Studio
10.0\VC\lib\amd64\MSVCRT.lib:
10.0\VC\lib\amd64\OLDNAMES.lib:
1>
1> Finished searching libraries
1>
1> Finished pass 1
1>
1>nntest.obj : error LNK2001: unresolved external symbol "class
boost::system::error_category const & __cdecl
boost::system::system_category(void)"
(?system_category@system@boost@@YAAEBVerror_category@12@XZ)
boost::system::generic_category(void)"
(?generic_category@system@boost@@YAAEBVerror_category@12@XZ)
1>C:\dev\tests\cgal_nn_test\nntest\x64\Release\nntest.exe : fatal error
LNK1120: 2 unresolved externals
1>
- [cgal-discuss] Another boring linking question, Rhys D, 01/23/2013
- Re: [cgal-discuss] Another boring linking question, Sebastien Loriot (GeometryFactory), 01/23/2013
- Re: [cgal-discuss] Another boring linking question, Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: [cgal-discuss] Another boring linking question, Rhys D, 01/23/2013
