Re: [cgal-discuss] Given a list of lines, and a test point, can I find the line index that is the nearest to the test point?
- To:
- Subject: Re: [cgal-discuss] Given a list of lines, and a test point, can I find the line index that is the nearest to the test point?
- Date: Wed, 23 Jan 2013 11:07:36 +0100
Le lundi 21 janvier 2013 23:05:46 goshhukha a écrit :
> I have a list of lines ( or rather, a polyline
> <http://www.webopedia.com/TERM/P/polyline.html> ), and given a test point,
> I want to test the test point on that list of lines, so that I will get the
> line and the index of the line that is the closest to the test point?
> Is there anyway I can do this using existing cgal library, instead of doing
> it in a brute force manner, namely, looping through all the lines and test
> each line against the test point in the naive manner?
If your polylines are in 3D, I think that the AABB_tree package from CGAL is
the right tool to use. See the documentation here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree/Chapter_main.html
Laurent Rineau, PhD
- [cgal-discuss] Given a list of lines, and a test point, can I find the line index that is the nearest to the test point?, goshhukha, 01/22/2013
- [cgal-discuss] Re: Given a list of lines, and a test point, can I find the line index that is the nearest to the test point?, xiaoyou, 01/23/2013
- Re: [cgal-discuss] Given a list of lines, and a test point, can I find the line index that is the nearest to the test point?, Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
