- To:
- Subject: Re: [cgal-discuss] Getting a Triangle from Facet_iterator
- Date: Sat, 26 Jan 2013 11:41:59 -0200
Thank you for answer.
But I've another problem. When I've draw the triangles in OpenGL, the image appears very strange… I need triangulate and see correct contour.
I've tried Alpha_Shape_3 example using ./data/bunny_1000 and the image is attached …
Any Idea?
Thank you in advance.
Sidnei Basei
On Saturday, January 26, 2013 at 3:45 AM, Andreas Fabri wrote:
that when you dereference the iterator you get a Facet.
Description: PNG image
- [cgal-discuss] Getting a Triangle from Facet_iterator, Sidnei Basei, 01/25/2013
- Re: [cgal-discuss] Getting a Triangle from Facet_iterator, Andreas Fabri, 01/26/2013
- Re: [cgal-discuss] Getting a Triangle from Facet_iterator, Sidnei Basei, 01/26/2013
