- To: Cody Rose <>
- Cc:
- Subject: Re: [cgal-discuss] problem with BOOST_RESULT_OF_USE_DECLTYPE
- Date: Wed, 30 Jan 2013 11:39:03 +0100
Cody Rose
writes:
> Hello,
> With CGAL 4.1 I am unable to use the Nef_polyhedron_3 package with
> BOOST_RESULT_OF_USE_DECLTYPE defined. I am using:
You have to define BOOST_RESULT_OF_USE_DECLTYPE because your compiler
does not implement a fully conforming decltype. (AFAIK, the only
compiler that currently does is clang 3.2).
> CGAL 4.1
> the CORE numeric library, along with its dependencies (GMP etc)
> Boost 1.47
> Visual Studio 2010
> The problem does *not* appear in CGAL 3.9.
CGAL 3.9 didn't use result_of. That's why you don't see the problem.
> The following code reproduces the problem for me:
> // This is the problematic define.
> #define BOOST_RESULT_OF_USE_DECLTYPE
> #include <vector>
> #include <boost/range/algorithm.hpp>
> #include <boost/range/adaptors.hpp>
> #include <CGAL/Cartesian.h>
> #include <CGAL/CORE_Expr.h>
> #include <CGAL/Nef_polyhedron_3.h>
> typedef CORE::Expr NT;
> typedef CGAL::Cartesian<NT> K;
> typedef CGAL::Nef_polyhedron_3<K> nef_polyhedron_3;
> int main() {
> std::vector<int> a(0, 3);
> a[0] = 1;
> a[1] = 2;
> a[3] = 3;
> std::vector<int> b;
> // With BOOST_RESULT_OF_USE_DECLTYPE defined, the following line
> causes an error.
> nef_polyhedron_3 foo;
This is because MSVC decltype triggers instantiation prematurely.
> // Without BOOST_RESULT_OF_USE_DECLTYPE defined, the following
> line causes an error.
This is because built-in lambdas require a decltype based result_of.
> boost::copy(a | boost::adaptors::transformed([](int x) { return x
> * 2; }), std::back_inserter(b)); return 0; }
It would be nice if both worked together, even with a broken
decltype. If I remember correctly there was a work-around involving two
Type_equality_wrappers when instantiating kernels.
- [cgal-discuss] problem with BOOST_RESULT_OF_USE_DECLTYPE, Cody Rose, 01/29/2013
- Re: [cgal-discuss] problem with BOOST_RESULT_OF_USE_DECLTYPE, Philipp Moeller, 01/30/2013
- Re: [cgal-discuss] problem with BOOST_RESULT_OF_USE_DECLTYPE, Sebastien Loriot (GeometryFactory), 01/30/2013
- Re: [cgal-discuss] problem with BOOST_RESULT_OF_USE_DECLTYPE, Cody Rose, 01/30/2013
