- To:
- Subject: Re: Re: Re: [cgal-discuss] running a demo on ubuntu Linux
- Date: Fri, 01 Feb 2013 16:32:27 +0100
Le jeudi 31 janvier 2013 10:59:29 sara ershadi a écrit :
> Dear Laurent ,
> Hi ,
> I went to build folder and delete all the past exist file. and then use
> Cmake-gui to create the build again . and then configure 2 times and then
> generate .I test this procedure 4 times with CGAL_dir from source or
> CGAL-dev path . and in Debug or release mode . this is not any change in
> the output error and I usually see this : I have typed make VERBOSE=1
> clean AABB_demo
> too . this is the result :
Thanks for the report. Now I understand. It seems that the FindQGLViewer
CMake
module found the Qt3 version of libqglviewer, instead of the Qt4 one.
Please install the package named "libqglviewer-qt4-dev", and *uninstall* the
package "libqglviewer-qt3-dev".
Laurent Rineau, PhD
- Re: Re: Re: [cgal-discuss] running a demo on ubuntu Linux, Laurent Rineau (CGAL/GeometryFactory), 02/01/2013
- Re: [cgal-discuss] running a demo on ubuntu Linux, sara ershadi, 02/01/2013
- Re: Re: [cgal-discuss] running a demo on ubuntu Linux, Laurent Rineau (CGAL/GeometryFactory), 02/04/2013
