- To:
- Subject: Re: [cgal-discuss] bug: circumcenter with Regular_triangulation_3
- Date: Fri, 08 Feb 2013 10:03:49 +0100
It's an inheritance problem, Weighted_point inherits from the point
which is documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Weighted_point.html
I'm afraid, there is not much we can do about it.
Sebastien.
On 02/08/2013 10:00 AM, Tom Dreyfus wrote:
Hi,
thank you for the answer.
However, I am not sure that it is normal that the method circumcenter()
returns the (not weighted) circumcenter associated to a Cell in the
Regular_triangulation. The circumcenter is associated to a set of
points, and the weighted circumcenter is associated to a set of weighted
points: the possiblity to use the not weighted circumcenter in the
regular triangulation may be confusing and may lead to errors. Or at
least, it should be mentionned somewhere in the documentation.
Tom.
*De: *"Fernando de Goes"
*À:
*Cc:
*Envoyé: *Jeudi 7 Février 2013 18:14:59
*Objet: *Re: [cgal-discuss] bug: circumcenter with
hi Tom,
Regular_triangulation is a weighted Delaunay triangulation and its
dual is a weighted circumcenter, ie, the circumcenter plus a
displacement that depends on the vertex weights.
When the weights of the vertices of a triangle have different values
(and that's the case in your file bug.txt), the dual will be always
different than the circumcenter.
When all the weights are the same, the weighted Delaunay
triangulation reduces to a Delaunay triangulation and then the dual
coincides with the circumcenter.
On Thu, Feb 7, 2013 at 9:07 AM, Tom Dreyfus
<mailto:>>
wrote:
Hello,
The methods Regular_triangulation_3::dual(Cell_handle) and
Cell::circumcenter(void) do not return the same point.
I join a short example.
Tom.
Fernando de Goes
- [cgal-discuss] bug: circumcenter with Regular_triangulation_3, Tom Dreyfus, 02/07/2013
- Re: [cgal-discuss] bug: circumcenter with Regular_triangulation_3, Fernando de Goes, 02/07/2013
- Re: [cgal-discuss] bug: circumcenter with Regular_triangulation_3, Tom Dreyfus, 02/08/2013
- Re: [cgal-discuss] bug: circumcenter with Regular_triangulation_3, Sebastien Loriot (GeometryFactory), 02/08/2013
- Re: [cgal-discuss] bug: circumcenter with Regular_triangulation_3, Monique Teillaud, 02/08/2013
- Re: [cgal-discuss] bug: circumcenter with Regular_triangulation_3, Nico Kruithof, 02/07/2013
